Author Topic: Optimum Anti Freeze Rate?  (Read 850 times)
Offline AMXguy
« on: January 30, 2009 - 05:40:51 PM »
When you look at an anti freeze protection mix chart are they saying you're good to that temp before you have trouble or that's where you freeze solid? I know from experience in farm equipment a small amount of anti freeze will prevent freeze damage but I don't know what that rate is.
 We all know water cools better than anti freeze but I live where it can get to 20 below, I don't drive the car in the winter so I want o keep my rate down but not have to worry about freeze damage. the chart shows 1 gallon in a 15 quart system protects to 8 above, I think they mean you can drive it in 8 degree weather, or does that mean you push freeze plugs below that?
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Offline Changin Gears
Re: Optimum Anti Freeze Rate?
« Reply #1 on: January 30, 2009 - 05:44:13 PM »
The chart has nothing to do with driving, that is the temp the mixture will freeze at.
« Reply #2 on: January 30, 2009 - 06:04:35 PM »
Unless you have some serious heating issues, I think most of us keep a 50/50 mix to keep it simple.
Offline quagmire
  • Traction Impaired......
« Reply #3 on: January 30, 2009 - 06:53:34 PM »
50/50 is generally ideal, any different than that and you start running into potential cooling, freeze protection, lubrication, and corrosion protection problems.
Offline AMXguy
« Reply #4 on: January 30, 2009 - 08:36:59 PM »
That's what I've always done, I was just thinking since the label on Royal purples coolant junk says 20% anti freeze is enough for a sreet car I'd see what others are doing. they probably figure everyone lives in California or something, but I know a little bit of anti freeze keep things from freezing solid  in some real cold weather it just gets slushy.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #5 on: January 30, 2009 - 09:55:12 PM »
you have to be 60/40 here minimum
Offline heminut
« Reply #6 on: February 02, 2009 - 07:44:06 PM »
Don't rely on those plugs to come out before the freezing damages a block or head, that's not their purpose! :nono:
1970 5.7 Hemi Cuda
