Author Topic: Disc brake kits  (Read 1070 times)
Disc brake kits
« on: February 01, 2009 - 02:57:56 PM »
I've put together a couple of disc brake kits that I'm offering for sale. You'll need to pay shipping form 80907 to your location. PM here or email highplains@comcast.net
Viper kit
Contains a pair of used Viper calipers, viper pads, viper hoses (may or may not work for each application), new AR Engineering caliper brackets, new big disc bearing adapter. The bearing adapter allows you to put the big 11.75 rotors on to standard, pre-73 small bearing drum spindle. This does not include the 11.75 rotors and bearings, which you can get locally or from Rock Auto for less than I can, or the master cylinder push rod. This kit will NOT bolt to disc spindles. It requires drum spindles to work. $600
Wilwood kit
Contains a pair of new Dynalite calipers, new poly matrix pads, new AR Engineering caliper brackets, a pair of disc brake spindles. This does not include the 11.75 rotors and bearings, which you can get locally or from Rock Auto for less than I can, or the master cylinder push rod. $550
« Last Edit: February 08, 2009 - 06:27:28 AM by HP2 »
Re: Disc brake kits
« Reply #1 on: March 22, 2009 - 08:57:03 PM »
Viper kit is sold!!
Still have the Wilwood set up.
Re: Disc brake kits
« Reply #2 on: April 04, 2009 - 11:25:41 AM »
Wilwood kit
Contains a pair of new Dynalite calipers, new poly matrix pads, new AR Engineering caliper brackets, a pair of disc brake spindles. This does not include the 11.75 rotors and bearings, which you can get locally or from Rock Auto for less than I can. $515
Stock kit
Pair of disc brake spindles and a pair of 11.75 slider caliper adapters. $200. Does not include calipers, pads, rotors, or bearings.
Viper brackets
I've got a set of Viper caliper bracket adapters. These are AR Engineering brackets that bolt to your drum spindles and utilize 1st Gen Viper calipers. I'll also include the large bearing adapter and seal to use them on your small bearing spindles, Does not include calipers, rotors, or bearings. $250
