Author Topic: 3/8 sending unit  (Read 4134 times)
Offline mopardave
  • Sponsor
    • rosevillemoparts
Re: 3/8 sending unit
« Reply #15 on: February 04, 2009 - 10:31:50 AM »
got it thanks
Mopar Dave
Rosevillemoparts.com
70 FK5 Challenger RT/SE
70 FC7 70 Road Runner - Sold
71 FM3 Challenger RT
73 F8 Challenger
1990 XJ - sold
2000 Dakota Quad Cab
Offline pink panther
« Reply #16 on: February 10, 2009 - 09:52:15 AM »
I recieved it yesterday Dave, thanks and great customer service  :thumbsup:
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #17 on: February 10, 2009 - 11:28:57 AM »
no problem, thank you
Mopar Dave
73 F8 Challenger
1990 XJ - sold
« Reply #18 on: March 07, 2009 - 05:57:42 PM »
just put it in Dave, works great!
« Reply #19 on: March 07, 2009 - 06:43:06 PM »
I just put in my new sending unit from Dave at roeville, it works great! anyone that needs parts I highly reccomend Dave, customer service is great.
Good job Dave!
After I changed my sending unit, it is the the thin metal strap that had come un-done, I had already sanded the output tube and clamped another ground to the unit and it worked for just about 6 months.
My question is this:
can someone solder or rivet the flat strap back in place on removed units? It took me about 2 hours to change it as I had to wait for gas to drain and then to try and get the sending unit back in as it tended to float a little, so it was difficult to keep straight at the gas tank housing.  But, I think if the strap was connected it would not have failed.  I will try and re-attach to my old unit and use a  volt meter to see if it works.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #20 on: March 07, 2009 - 06:52:46 PM »
other thing you could try is to take a piece of wire and 2 small worm clamps and attatch it that way. then it is secure and wont move around with vibrations. I have done this and it works well, give you a solid ground by clamps, plus you wont have to remove anything
Mopar Dave
73 F8 Challenger
1990 XJ - sold
« Reply #21 on: March 07, 2009 - 06:56:26 PM »
Dave,
the new unit works fine, I'm talking about the old unit, can a person solder the strap back on? I guess I really don't care since it is fairly cheap repair, just curious.
Offline mopardave
  • Sponsor
    • rosevillemoparts
« Reply #22 on: March 07, 2009 - 06:58:38 PM »
yep they could if they wanted to.  a little brazing will do, or spot weld
Mopar Dave
73 F8 Challenger
1990 XJ - sold
