Author Topic: Oil Pressure Tap  (Read 576 times)
Offline the_engineers
Oil Pressure Tap
« on: February 02, 2009 - 11:57:24 AM »
Small Block Owners:
For those who are using an oil pressure safety switch to control an electric fuel pump AND an oil pressure sending unit or gauge, where are you tapping in for both of these?  Are you using a Tee fitting next to the distributor or is there another location to get oil pressure from?
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline quagmire
  • Traction Impaired......
Re: Oil Pressure Tap
« Reply #1 on: February 02, 2009 - 12:36:54 PM »
I am using a tee, I don't think there are any other plugs to get oil pressure off of the small blocks.
« Reply #2 on: February 02, 2009 - 01:26:35 PM »
that is the only connection for oil pressure so you need to use a tee
