sounds stupid, but need a way to siphon gas
Author Topic: sounds stupid, but need a way to siphon gas  (Read 4442 times)
Offline priderocks
« on: February 02, 2009 - 12:05:06 PM »
My days of ending up with mouthfuls of gas are over. I need some kind of device, like a manual pump thingy, to effectively pump out gasoline. You would think this would be a straightforward thing, pretty easy to find, but I can't. My first thought was the Northern Tool catalog, but can't find anything in there. Any suggestions?
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: sounds stupid, but need a way to siphon gas
« Reply #1 on: February 02, 2009 - 12:09:06 PM »
When I saw the thread title I was going to tell you to get a hose and suck on it. I would check places like Harbor Freight or Ace hardware, you should be able to find a manual hand pump or one that can attach to your drill. My Dad got a manual pump from an Ace Hardware but that was about 10 years ago.
1996 Dodge Viper GTS Coupe
Offline 426HEMI
« Reply #2 on: February 02, 2009 - 12:12:02 PM »
I would suggest that you go to a truck stop they usually have them with a ball type.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline farmertan
« Reply #3 on: February 02, 2009 - 12:48:37 PM »
i take a hose and about 4in from the end cut a notch then put your blow gun from air hose in notch and put it in the gas can,once you get fuel going it continues by itself. warniing works really good with diesel but with gas it will mist, do not do it near anything that could ignite the mist.
73 340 4sp 2nd owner since 85    brett
Offline NoMope Greg
« Reply #4 on: February 02, 2009 - 01:11:18 PM »
At work, our shop foreman found a hand-cranked bilge pump that works really well for moving large amounts of coolant back into the bus when we have to drain the coolant on a road call.  I've seen it in action - it's not hard to use and the mechanic moved at least 10 gallons of coolant in under five minutes.  Try a marine supply shop.
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
Offline Andrew
« Reply #5 on: February 02, 2009 - 02:34:07 PM »
You need a flowN'go. Its a small hand operated pump, just to get the syphon started. - then gravity takes over.
Offline tactransman
Terry-tactransman
Union, Mo.
Offline Oldschool
  • Member Since 9-05-06
« Reply #7 on: February 02, 2009 - 03:37:52 PM »
You don't need anything but a section of whatever hose you are gonna use.  Fill the hose up with water and hold you thumb over the exposed end and place the other end in the tank to be drained.  Lower the end in your hand to below tank level and release your thumb. The water in the hose will drain and "pull" the gas out of the tank.  Hold the hose over the ground until the gas starts to flow then place the end in whatever container you desire.  No sucking on a hose, and nothing to buy.....    :2cents:
BTW -- we always called a 6 foot section of hose an "alabama credit card"....    :roflsmiley:     :cooldancing:
Ken  --  In Georgia
Offline arcticmopar
  • Yukon Canada
« Reply #8 on: February 02, 2009 - 04:03:45 PM »
I just use 2 pieces of hose conneted to an outboard motor primer bulb. It has a one way valve in it and an arrow showing the flow. They are used to prime the fuel systems of small outboard boat motors, just give it a couple of squeazes and it will sart to flow. :cheers:
RUNS WHITH SISSORS!  and  DIGITALY CHALLENGED!
Offline wally426ci
    • maryland mopars
« Reply #9 on: February 02, 2009 - 04:13:55 PM »
just put your lips together and blow.... oh wait a minute.   :poopoke:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline the_engineers
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
Offline 4Cruizn
  • HEMI FISH
« Reply #11 on: February 02, 2009 - 11:08:18 PM »
We always just used clear hose.  Then you can see the stuff coming!   :naughty:
Offline Moparal
« Reply #12 on: February 02, 2009 - 11:28:58 PM »
 :stomp: :swear: :swaying:   yeah   I ressemble that remark
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #13 on: February 03, 2009 - 04:26:20 AM »
I googled that term and came up with this.
http://www.google.com/search?hl=en&rls=com.microsoft:*&sa=X&oi=spell&resnum=1&ct=result&cd=1&q=gas+siphon+pump&spell=1
Go Fast & Have Fun...
Offline CrazyPete
1970 Dodge Challenger T/A      http://heartlandmopars.com
1970 Plymouth Barracuda Gran Coupe
1976 Dodge Dart Sport
"Is that an oil leak?  No it's just sweat from all that HORSEPOWER"
