Author Topic: What to use to remove the Argent paint ,update  (Read 2566 times)
« on: February 03, 2009 - 10:05:14 PM »
What would you use to get the argent paint off the anodizerd 70 grille & not hurt the alum below ??
« Last Edit: February 04, 2009 - 07:53:06 PM by Chryco Psycho »
Offline 71bigblock
    • Steve's Mopars
Re: What to use to remove the Argent paint
« Reply #1 on: February 03, 2009 - 10:27:51 PM »
Can you just lightly sand it and paint again?
« Reply #2 on: February 03, 2009 - 10:37:26 PM »
I buy this at the local Advanced Auto Parts....says its safe on aluminum
 Mar-Hyde Aircraft Coating Remover: Talstrp II; Aerosol; 11 oz.
 http://shop.advanceautoparts.com/ProductDetail.aspx?MfrCode=MHY&MfrPartNumber=3711&CategoryCode=3272
Offline elitecustombody
  • Supra collector
« Reply #3 on: February 03, 2009 - 11:55:57 PM »
yep, aerosol paint stripper will work just fine,follow instructions on the label, make sure you don't get any of that stuff on cars around or your skin,
Stefan B
Offline 72bluNblu
« Reply #4 on: February 03, 2009 - 11:59:14 PM »
:iagree: Just rinse it off soon after the paint bubbles to avoid damaging the anodizing. It shouldn't be an issue, i just wouldn't leave it on for a long time...
And if you feel your skin getting warm, rinse with lots of water, quickly!  :22yikes:
« Last Edit: February 04, 2009 - 12:00:47 AM by 72bluNblu »
« Reply #5 on: February 04, 2009 - 01:28:46 AM »
I definatly do not want to hurt the anodizing under the paint , the grille is virtually brand new but I assume the black R/T grille was not available when this was replaced in the mid 70s so the argent is perfect but wrong
Offline 72bluNblu
« Reply #6 on: February 04, 2009 - 02:21:52 AM »
If the argent was applied with a spray can it should come off almost immediately with that stripper, and short applications shouldn't do anything to bother the anodizing. Its actually pretty hard to remove anodizing, I had to sand it off of a clear anodized aluminum motorcycle rim (the anodizing was old, yellow, and damaged in places), and I couldn't come up with an easy chemical process (and I tried the stripper!). I just mentioned it because of the small possibility that if you left it on for hours it might somehow mar the finish, although that hasn't been my experience.
« Reply #7 on: February 04, 2009 - 03:04:04 AM »
it was applied by the factory & is the very coarse argent , somehow after 40 years I doubt it will be easy to remove but I dont want to hurt the anodizing , I will check on the aircraft stripper in the morning , I tryed the same stripper on the paint & it didn`t touch it but it turns out I had epoxy primer under the paint & it did nothing to lift it even the white exerior paint was untouched by it  :pullinghair:
Offline bb71challenger
« Reply #8 on: February 04, 2009 - 08:10:05 AM »
When I used aircraft stripper on a hood it was odd. Some places bubbled up and some places seemed unaffected. I put some on a few times and eventually it did the job.
*Brett*
Offline Roppa440
« Reply #9 on: February 04, 2009 - 08:30:13 AM »
A nylon brush helped work this stuff into the corners. A wooden chopstick helped dig out the difficult bits too.
« Last Edit: February 04, 2009 - 08:33:22 AM by Roppa440 »
1970 Challenger R/T
1997 Jeep Grand Cherokee Limited
« Reply #10 on: February 04, 2009 - 08:32:39 AM »
Wax will inhibit the process, scuffing paint 1st will help.
CP, have you tried good ole lacquer thinner?...may be the ticket.
Offline ShelbyDogg
« Reply #11 on: February 04, 2009 - 08:53:46 AM »
Try some brake fluid. It won't hut the aluminum. I always buy it by the quart.
  • Supra collector
« Reply #12 on: February 04, 2009 - 08:54:47 AM »
if there is absolutely nothing wrong with the existing paint, just mask off the rest of the grille, scuff the paint with red scotch pad and 400-600 grit paper,clean and shoot the right color
Stefan B
Offline Roppa440
« Reply #13 on: February 04, 2009 - 09:41:24 AM »
Argent is textured. Really rough. Very tough. The black R/T and T/A grilles were smooth. No way would you get the correct finish without removing the argent.
1970 Challenger R/T
  • Supra collector
« Reply #14 on: February 04, 2009 - 10:44:44 AM »
I know,that,but I'm sure sandpaper can smooth it down,I just figured to post that option as well
Stefan B
