Author Topic: Drive Shaft Balancing  (Read 711 times)
Offline cwestra
« on: February 05, 2009 - 12:00:24 PM »
Do drive shafts ever require re-balancing due to;
- rusty driveshafts sanded and repainted?
- replacement of U-joints?
- small dents?
- etc...?
Corey - in Northern Indiana
Re: Drive Shaft Balancing
« Reply #1 on: February 05, 2009 - 02:07:04 PM »
I'd be leary to run a rusty shaft or dented one.   Surface rust no, dents, I'd have checked, u joints no problem
Offline NorthWestcuda
« Reply #2 on: February 06, 2009 - 01:16:33 PM »
     Having worked on drive shafts "along time ago" in a NAPA machine shop, I would never assume a factory shaft is REALLY straight and balanced let alone a 38 year old shaft.  If you have a dent(even a small dent) in the shaft definitely take it to a drive line shop and have it looked at.  Depending on the size of the dent the driveline may need new tubing.  With the horsepower and speed in some of these cars it makes alot of sense to run a balanced and straight shaft.
    FYI, I just took my driveline in and had it balanced and straighted. If I remember correctly it was "out of straight" something like .050. I may not feel the difference next summer but at least I know the drive line is not causing problems.  I THINK I HAD TOO MUCH FUN LAST SUMMER.!!!!!
« Last Edit: February 08, 2009 - 12:12:20 PM by NorthWestcuda »
1973 Cuda, 440 engine
1972 Chevy 4x4 PU stepside
2003 Ford F-350 Diesel
