Author Topic: What Fan for my 340?  (Read 826 times)
Offline challengermaniac
« on: February 07, 2009 - 01:04:16 AM »
I am pulling the 318 and installing a 340 motor and just wanted to know what fan (original or repro) I should get, assuming I am going to install a 26" radiator (ps, pd, 727, no a/c).   Also, would someone kindly explain the difference between a standard and clutch type fan and do I have an option for using either one for my setup?
Thanks, Charlie
70 Challenger
Charlie
70 Challenger 340/4 Purple
70 Challenger T/A Red
Edmonds, WA
Re: What Fan for my 340?
« Reply #1 on: February 07, 2009 - 01:26:31 AM »
18" , you can use a fixed fan or a clutch type , fixed runs at engine RPM , clutch unlocks when cold air is passing through the rad & locks up when hot air is passing througn , this increases cooling when the rad is hot & decreases drag when not needed such as on the highway . .I always use clutch fans
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #2 on: February 07, 2009 - 02:09:27 AM »
My '73 Cuda came with figure 17 (see pic below) from the factory with a 22" radiator.
« Last Edit: February 07, 2009 - 02:11:48 AM by hooD »
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline RT Dude
« Reply #3 on: February 08, 2009 - 10:25:07 PM »
Hey Charlie
We recently replaced the fan on our '70 Cuda 340 as it had a lot of play in it.
It was originally supplied with a "torque clutch type" (called a "non thermal") fan. It was at some point changed to a "Thermal Clutch type" (called a "Thermal").
After a lot of searching for a new one here (as we just cant buy off the shelf parts for E-body's in New Zealand) we finally found and fitted a "Thermal Heavy Duty" type. It was made by Flex-A-Lite in USA.
Hope this helps.
Brent
« Reply #4 on: February 09, 2009 - 03:34:11 AM »
Flex-A-Lite also makes a 18 " 6 blade fan to work with the clutch
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #5 on: February 09, 2009 - 05:46:04 PM »
use the fan form the 318
