Author Topic: Sunvisors  (Read 1038 times)
Offline Purple73Cuda
Sunvisors
« on: February 07, 2009 - 03:12:16 PM »
On my '73 'Cuda, the sunvisors hit the rearview mirror when I put them down. How long should the sunvisors be? How far away from the A pillar do they mount? I suspect I either have the wrong visors or they are mounted in the wrong spot. They seem to be mounted too far away from the A pillar. Any help would be appreciated.
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Re: Sunvisors
« Reply #1 on: February 08, 2009 - 03:47:46 AM »
the 3 screw anchor is welded into the roof & there is only one place to mount them , they will slide down the steel rod though & may have slid up the rod too far
Offline IMNCARN82
  • LeDZeP
Re: Sunvisors
« Reply #2 on: February 09, 2009 - 03:45:53 PM »
That's funny...  Mine hit too.  :dunno:Just on the drivers side.  They are slid all the way in.Mayby try adjusting the rearview to point over just a bit?
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Re: Sunvisors
« Reply #3 on: February 09, 2009 - 07:17:13 PM »
I tried adjusting the mirror. Both visors hit. I can adjust the mirror so that the driver's visor doesn't hit if no one is riding with me.
I want to pull the front molding off and see if the visors are screwed into the factory holes. I have a feeling they aren't.
Maybe the rearview mirror is wrong? Maybe it is wider because it came off a C body? I am just thinking out loud.
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Re: Sunvisors
« Reply #4 on: February 09, 2009 - 07:31:29 PM »
Relax, what you have is normal.  :grinyes:
I have a 70, but if I pull both down...at least one of them will bang the mirror.
Re: Sunvisors
« Reply #5 on: February 10, 2009 - 12:29:05 PM »
Thanks. I didn't realize it was normal. It is very annoying!!Luckily my b body doesn't do that.
Is this a sign of the Chrysler fit and finish quality back then?
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Re: Sunvisors
« Reply #6 on: June 19, 2009 - 03:41:15 PM »
I just discovered that I have the wrong rear view mirror in the car. What is in there is 12 3/4" at its widest point. I am going to pick up a rearview out of a '72 'Cuda tomorrow. The guy measured it for me, it measures 8 3/4" wide. Just wanted too let everyone know what I found. This will solve my problem of the visors hitting the rearview mirror.
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
