Author Topic: finally dug out of its grave!!  (Read 104331 times)
wagesofsin
Re: finally dug out of its grave!!
« Reply #345 on: June 30, 2010 - 06:08:39 PM »
John that is friggin genius. Now if I could only go back to when my car was original and do that trick.  :lol2:
PS: I would like to share a piece of your cake.  :misbehaving:
 :sly:
bwahahahahahahahahahahaha
Offline mopar12372
    • mopartech
« Reply #346 on: June 30, 2010 - 10:39:32 PM »
PS: I would like to share a piece of your cake........ :scared:
buhahahahahahahahahaha
RESTO PICTURES
Offline wally426ci
    • maryland mopars
« Reply #347 on: July 03, 2010 - 09:05:43 AM »
Inside Joke.  :grinyes:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
wagesofsin
« Reply #348 on: July 04, 2010 - 04:45:41 PM »
got the dash tuned up and back in.
just a cap ,and it fits pretty good , although they forgot to open up the vin area , and i just left the speakers perfed , although my original speakers mounted over the pad.but it looks ok for now.
« Last Edit: July 04, 2010 - 04:47:57 PM by wagesofsin »
Offline dutch
« Reply #349 on: July 04, 2010 - 04:56:30 PM »
that cap looks pretty good from here... where did you get it from/ what manufacturer
*** Bart ***
wagesofsin
« Reply #350 on: July 04, 2010 - 05:09:02 PM »
i have no idea what mfg. i bought it from a guy on moparts a while ago.
it does fit alot better than the one on the challenger.
Offline dutch
« Reply #351 on: July 04, 2010 - 05:18:46 PM »
ok, thanks.
I guess a bit of luck is needed with parts like that too.
*** Bart ***
Offline wally426ci
    • maryland mopars
« Reply #352 on: July 04, 2010 - 05:24:33 PM »
That cap does look good!! You are gonna have us all using caps with the way that looks!!  :cheers:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
wagesofsin
« Reply #353 on: July 04, 2010 - 05:45:43 PM »
i found the destructions for the cap.
https://www.dashcaps.com/xcart/home.php
on the sheet i have it claims they make interior panels for challys and barracudas... couldnt find any info on the site , but ill call em.
oh and not fer nothing , i use 3m trim adhesive , the high strength , not the stuff they supply.
« Last Edit: July 04, 2010 - 05:48:06 PM by wagesofsin »
Offline dutch
« Reply #354 on: July 04, 2010 - 06:02:23 PM »
these glue right on top of the original cap?
*** Bart ***
wagesofsin
« Reply #355 on: July 04, 2010 - 06:20:47 PM »
yes .
you may want to actually trim off some of the cracked bits , or warped areas , fit , then trim , fit, etc. when it looks good , get a pile of bungee chords , and some 3m high strength trim adhesive. you want it to suck on good front to back, and then pull on an angle towards the back , then straight corner to corner across the back. wait 24 hours, and viola...
hopefully.
Offline dutch
« Reply #356 on: July 04, 2010 - 06:32:04 PM »
 :cheers:
gonna be fun shipping...  :faint:
*** Bart ***
wagesofsin
« Reply #357 on: July 04, 2010 - 06:49:46 PM »
:cheers:
if in fact you want one, lemme know, i can get it for you and ship it cheaper.
Offline quapman
    • Auto-Grip on Facebook
« Reply #358 on: July 04, 2010 - 06:57:13 PM »
I've done a few of these caps on E and B bodies and as wages suggests, use a good, quality contact adhesive and save the silicone to seal your bathtub.
The Palco interior panels are the ones everyone here on the board complains about being low quality and the wrong grain. I'll let you know when I finally install the set I bought  a couple years ago.....
Offline ShelbyDogg
« Reply #359 on: July 05, 2010 - 01:00:47 AM »
Be careful about gluing it too much. It should only be glued on the edges and around the open holes. When the sun hits it and your windows are rolled up, that cheap plastic starts expanding and shrinking.
That's funny that yours has perforated speaker holes. Are they right over the original speakers? They look like they are too far too the center.      I have a cap where the CENTER SPEAKER is just perforated holes, but the outside speakers, I was able to cut the holes and install the 3 speaker grills.
I use the silicone that comes with the caps. I use those binder clips that you get at the office supply store or in your office's supply cabinet.
