Author Topic: WHAT SHOULD A VACUUM GAUGE READ AT IDLE ?  (Read 4675 times)
Offline cudaneil
  • Mopar or Nocar ?
« on: February 09, 2009 - 07:12:38 PM »
  Hi,  Managed to get hold of a vac gauge to connect to my intake manifold.  Trying to find out why my 340 stalls at idle when
 I select drive !     If anyone can tell me what the gauge should read at idle ?
        :cheers:   Cudaneil
just one more job to do..................  (O----{|||}----O)
Offline LAA66
Re: WHAT SHOULD A VACUUM GAUGE READ AT IDLE ?
« Reply #1 on: February 09, 2009 - 07:16:21 PM »
 It depends on a number of things including engine condition and what cam you are using. My 340 with a mild cam is 13-14".
Offline rallye73
  • Model cars for the big boys!!
« Reply #2 on: February 09, 2009 - 07:35:14 PM »
My SRT-4 reads 19"-20" at idle.
John Moorman
1971 Challenger R/T 383 4 speed (waiting it's turn)
1973 Challenger Rallye 340 4 speed (undergoing full resto)
2003 Dodge SRT-4 Stage 3 turbo daily driver-been as fast as 11.97et
1995 Dodge Neon Sport Coupe DOHC 5 speed Nitro-yellow-green (one of 527 built)
« Reply #3 on: February 09, 2009 - 07:52:37 PM »
It definitely depends on your cam. The more radical, the lower the reading. Anything from 10 on up is my guess.   :dunno:
Offline 422STROKER
  • Member Since 6/3/06
« Reply #4 on: February 09, 2009 - 08:12:26 PM »
Are all the vac lines connected?
Mine pulls 12-13" in gear.
Tom
You are looking for a steady reading either way.  Did your vac guage come with some paperwork(instructions)
Tom
craigsmytcudas
« Reply #5 on: February 09, 2009 - 09:47:33 PM »
I think what your looking for is not the range so much as fluxation in the needle this will tell you more . pull up a chiltons manual and look at the trouble shooting pages for the vacume diagram readings .c
« Reply #6 on: February 10, 2009 - 01:40:33 AM »
where is the vacuum adavnce connected to
Offline cudaneil
  • Mopar or Nocar ?
« Reply #7 on: February 10, 2009 - 04:51:28 AM »
            There just seems to be one vacuum hose,it goes from the holley to the distributor.
        thanks,Neil.
Offline cudaneil
  • Mopar or Nocar ?
« Reply #8 on: February 10, 2009 - 05:01:07 AM »
Tom
Its a borrowed vac gauge Tom,no instructions.
So im looking for  10 to 15  at idle................and it should stay there, not drop off when put into drive ?
    Thanks for the help everyone !!!   :cheers:    Neil.
« Last Edit: February 10, 2009 - 05:07:16 AM by cudaneil »
Offline Roppa440
« Reply #9 on: February 10, 2009 - 05:46:09 AM »
        thanks,Neil.
The one from the Holley to the distributor will not be connected to manifold vacuum if it is in the stock location.
That hose is normally attatched to the passenger side of the Holley metering block (between the fuel bowl and the carb main body).
If you have any vacuum on there at idle your carb is open too far and is not actually on the idle circuits at all. Usually this happens when someone fits a bigger than stock cam and does not know how to set the carb up correctly to work with it.
Is the car an automatic?
If it has a bigger cam it could be that the torque converter now does not have enough stall speed and when you put it in gear it is pulling the rpms down too far.
1970 Challenger R/T
1997 Jeep Grand Cherokee Limited
Offline willard
    • 1970 Challenger R/T
« Reply #10 on: February 10, 2009 - 06:03:56 AM »
here you have a simple manual. good luck.
1970 383 R/T SE
Offline Roppa440
« Reply #11 on: February 10, 2009 - 07:38:35 AM »
For that handy chart to work you need to connect to manifold vacuum and that will be a fitting right at the base of the carb. ;)
1970 Challenger R/T
Offline resq302
« Reply #12 on: February 10, 2009 - 10:18:59 AM »
Willard,
Great diagram of the vacuum gauge readings.  I have never seen that or even realized there was a method to determining all that kind of faulty areas.  Thanks for teaching me something new today!
Offline willard
« Reply #13 on: February 10, 2009 - 10:30:16 AM »
It seems easy while watching a chart, but diagnosing in reality is a bit difficult   :screwy:
1970 383 R/T SE
Offline 422STROKER
« Reply #14 on: February 10, 2009 - 05:52:39 PM »
You need to connect to manifold source as mentioned and it will drop in gear but hold steady.  If all is well.  with a rumpity cam it will be less than 10", stock is near 18-20".
Tom
Tom
