Author Topic: Removing front sway bar on 70 'cuda  (Read 575 times)
Offline usraptr
« on: February 10, 2009 - 03:04:17 PM »
Does the front sway bar thread through the K frame assembly or do you have to untack the welds on the plate that covers most of it.  I've removed all the bracets and can't seem to get it to slide through. If it does come out without messing with the plate, is there any secrets?
Thanks in advance
(Edited 8-1-17)
Re: Removing front sway bar on 70 'cuda
« Reply #1 on: February 10, 2009 - 03:22:34 PM »
does slide out...try flipping it in the k-frame 1st
Offline dutch
« Reply #2 on: February 10, 2009 - 03:23:02 PM »
you should be able to slide it out if you angle it down a bit...
*** Bart ***
Offline usraptr
« Reply #3 on: February 10, 2009 - 03:31:01 PM »
Thanks guys,
I'll try it again.
(Edited 8-1-17)
