Author Topic: Antifreeze and oil comming out of exhaust ???  (Read 1583 times)
Offline acudanut
« on: February 10, 2009 - 08:49:31 PM »
 I have (or thought I had) a good running 318.  When I went to try and start it, I could see antifreeze and a oil mixture comming out of my 1 foot pipes from my exhaust manifold.  No mistake about where it is comming from.
What do you guys think ?? Head gasket or intake problem ??
Offline The Cuda Guy
  • Support Our Troops
  • Pearl Harbor, HI
    • C-C.com
Re: Antifreeze and oil comming out of exhaust ???
« Reply #1 on: February 10, 2009 - 09:00:34 PM »
Sounds head gasket.
Don
Member Since January 14, 2002
Offline Oldschool
  • Member Since 9-05-06
« Reply #2 on: February 10, 2009 - 09:02:35 PM »
Pressure test the cooling system.  That should help you isolate the leaking coolant...    :cheers:
Ken  --  In Georgia
Offline acudanut
« Reply #3 on: February 10, 2009 - 09:19:04 PM »
Man, I just got that engine looking damn good too.  All I did was put a different intake manifold on it, BUT that head may have been leaking before and I just never caught it. (Had full exhaust pipes on it and I couldn't see it)
« Reply #4 on: February 11, 2009 - 02:34:50 AM »
you are sure it is antifreeze not just moisture , second on a small block the end studs go into water so it could be leaking from the stud into the exhaust header / manifold , it is also possible the AF is leaking into the cylinder from the head gasket but it should be exiting as steam if it was possible to detect at all  , last possibilty is a crack in the head beside the exhaust port .
 As Oldschool said borrow a pressure tester
Offline IMNCARN82
  • LeDZeP
« Reply #5 on: February 11, 2009 - 08:18:58 AM »
most all cars blow carbon/water until warmed up.  You sure it's oil/coolant?
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
« Reply #6 on: February 11, 2009 - 10:39:57 AM »
It ran good before changing the intake?
Offline acudanut
« Reply #7 on: February 11, 2009 - 10:42:06 AM »
 I am 100 percent sure it is a oil and antifreeze mixture.  My exhaust is only one foot long (going dual exhaust) and I can see it clearly pouring out the pipe. (not condensation).  Antifreeze still looks clean in radiator, and engine oil is not contaminated.  I guess I am going to pull the newer intake back off (just installed it) and check that out first.  If that looks good then I will pull the head and have a Machine shop check it out closely.
I am betting it is a crack near the exhaust port.
I will keep you updated. Thanks for the input. :thumbsup:
Offline acudanut
« Reply #8 on: February 11, 2009 - 10:43:01 AM »
  Yes it ran great before the intake swap. :banghead:
« Reply #9 on: February 11, 2009 - 12:15:40 PM »
You may just have an intake leak causing the problem
Offline acudanut
« Reply #10 on: February 11, 2009 - 01:50:33 PM »
 Found the problem. The new intake manifold is leaking antifreeze into the engine and entering  into the intake/fuel and air port.  What is the deal. Bad/wrong intake gaskets.
« Last Edit: February 11, 2009 - 10:43:13 PM by acudanut »
« Reply #11 on: February 11, 2009 - 02:53:29 PM »
virtually all the the intakes I have seen do not have a rear water passage , what they do have though is a water port on both ends of the cylinder head so the head can be installed on either side of the engine , the intake seals off the rear port
Offline acudanut
« Reply #12 on: February 11, 2009 - 07:46:41 PM »
Chryco, Okay I feel stupid..(Your right).. However, it was my intake causing all these problems.  The intake seals all matched up. I wonder what gives ??
Offline acudanut
« Reply #13 on: February 11, 2009 - 10:38:38 PM »
here is some pic's. You may need to enlarge them.
Notice how this intake is so thick, that it made the valve covers bend,
« Reply #14 on: February 12, 2009 - 03:56:04 AM »
Poor quality gasket maybe ?
