Author Topic: Antifreeze and oil comming out of exhaust ???  (Read 1584 times)
Offline rallyechall
Re: Antifreeze and oil comming out of exhaust ???
« Reply #15 on: February 12, 2009 - 07:38:31 AM »
Use a straight edge along the gasket surfaces of the intake. Perhaps it is a bad casting? Were the heads milled, and the intake was not milled to compensate?
Offline acudanut
« Reply #16 on: February 12, 2009 - 02:23:05 PM »
 I was using a older felpro intake gasket kit (plain metal).  BUT, after buying a new felpro gasket kit, it looks like might have been missing those four plastic gap fillers that go into the gasket/head plus the new gaskets is blue paper with metal inside with those plastic gap fillers, and I am sure this will SEAL this time.             I also used pertatex ultra blue silicone on both sides of the gaskets. It better seal. I'll keep you posted. Thanks. MIke
Offline acudanut
« Reply #17 on: March 07, 2009 - 11:24:09 AM »
  Problem fixed. Bad/wrong intake intake gasket.
« Reply #18 on: March 08, 2009 - 04:30:57 AM »
 :2thumbs:
