Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
.80 Over 440 Pistons?
« previous
next »
Print
Pages: [
1
Author
Topic: .80 Over 440 Pistons? (Read 1616 times)
AMXguy
Sr. Member
on:
February 10, 2009 - 09:07:50 PM »
Can you go more than .60 over on a 440? I have a '70 block I just bought cheap that's date coded perfect for my project but it's bored .30 over now and I'm skeptical if it will clean up at .60 over. if .80 pistons are an option who makes them? and are there any draw backs? I'd like to use this block but not bad enough to create problems or big expenses.
Logged
1970 R/T SE Challenger
1970 Superbee
1969 S code Mach 1
1967 GTO
The Cuda Guy
Support Our Troops
Resident
Pearl Harbor, HI
Re: .80 Over 440 Pistons?
Reply #1 on:
February 10, 2009 - 09:09:41 PM »
Why not try to go .065 and not go that high over 60.
Don
Logged
Member Since January 14, 2002
moper
Resident
Reply #2 on:
February 10, 2009 - 10:15:07 PM »
I dont believe .080 over is doable in any 440 block. But, for a bunch of extra money, you can sleeve whatever holes dont clean up. Even all 8 if necessary. Just make sure the shop you use is reputable.
Logged
AMXguy
Sr. Member
Reply #3 on:
February 11, 2009 - 01:05:27 AM »
I've been told a 440 had enough meat to go .80 over, maybe not. I guess I'll have it checked out and see if 60 or 65 will clean it up but I have my doubts. If it was the original block I'd go to the expense of sleeves if they were needed but I don't think a date code block would be worth it.
Logged
1970 Superbee
1969 S code Mach 1
1967 GTO
NoMope Greg
Resident
Reply #4 on:
February 11, 2009 - 01:45:28 AM »
I think by the time you go to the trouble and expense of sonic testing all the cylinder walls and then either sleeving the block or having custom pistons made, you'd be better off finding a rebuildable block. I had to do that with mine. My machine shop had one in storage and sold it to me for about $200.
Logged
Greg
2003 Ford Escape XLS
Currently Mopar-less
AMXguy
Sr. Member
Reply #5 on:
February 11, 2009 - 01:53:58 AM »
I think you're right, I have a real nice virgin 11-71 cast date one I just like the 5-69 better. it might clean up in .30 yet though, it has enough ridge you can feel it and some real light rust pitting, I'll have it checked but I don't know.
Logged
1970 Superbee
1969 S code Mach 1
1967 GTO
Kapteenikosmos
Jr. Member
Reply #6 on:
February 11, 2009 - 02:16:48 AM »
Is it even possible to drive a typical engine so long that .30 over bore wont clear it up? I mean, that is lots of ridge. If the bore starts to be almost .30 over because of the wear I would assume that there are hardly any rings left (if original) and the blow by would be pretty hard?
I had something that felt like an huge ridge on my 383 (and considering the overall shape of the engine, it had seen a lots of miles) but it cleaned out easily with .30 overbore. Things get different if there are scratches or something else because of internal failure.
Logged
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
Chryco Psycho
Administrator
C-C.com Guru
Reply #7 on:
February 11, 2009 - 02:38:17 AM »
the block can be tested with a sonic tester & I have seen some blocks with .300 thick walls & the minimum is .125 on the thrust side so yes it could possibly be done & you can get a custom piston for not a whole lot more than a std replacement piston .
It may not clean up due to rust & pitting not just ridge
Logged
nivvy
Guest
Reply #8 on:
February 11, 2009 - 05:29:47 AM »
thats trouble waiting to happen.... find another block.....
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
