Here's my brake line routing and park brake cables. For the brake line, was much easier than expected, moved the line outboard under the seat, added a bend or two, and routed line thru existing hole in trany Xmember. Will do the same for fuel line.
For park brake, the cables route above the subframe connectors, so pushes the cable against bottom of floor more than before. Adjusted easily and seems to work fine. Probably not up to factory design standards, but I don't use P-brake much and it does work A-OK.
