Author Topic: Original Big Block PCV Valves?  (Read 812 times)
Offline AMXguy
« on: February 11, 2009 - 11:04:59 AM »
Anyone know what an original PCV looked like? I've seen steel with a 90 degree elbow, black plastic with an elbow, white plastic you name it all sold as NOS. what would be correct for '70?
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Re: Original Big Block PCV Valves?
« Reply #1 on: February 11, 2009 - 11:15:27 AM »
I was told white plastic elbow but I am not sure if that is right or wrong
Offline oldkimmer
« Reply #2 on: February 16, 2009 - 04:31:30 PM »
 :canada:...........CP is absolutely right......white plastic elbow is 1970 up till end of production on all big blocks and 1790 up on all LAs............kim............
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
« Reply #3 on: February 16, 2009 - 07:11:05 PM »
That steel elbow PCV valve was used in the late 60's.
Offline somedaysoon
« Reply #4 on: February 16, 2009 - 08:39:24 PM »
 I think the top is white, but the bottom is black. I'm almost positive the one I have in a box is the original piece. Could be wrong but I've owned this thing since '76.  Pete
Offline AMXguy
« Reply #5 on: February 17, 2009 - 01:39:54 AM »
You're right, I looked on ebait and they're repoping the 70-71 Mopar PCV's and they're a white plasic elbow with a black steel base.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
