Author Topic: Quarter window shoulder bolts  (Read 893 times)
Offline Jim
« on: February 11, 2009 - 07:56:13 PM »
I was in the process of adjusting the quarter windows on my 72 Cuda when I realized the bolts attaching the glide to the glass is wrong.
It should be a shoulder bolt with that goes through a spring and glide that allows the glass to pivot in and out as it goes down the rail.
I don't have these bolts, but I figure I can cobble something together. I just need some basic dimensions. I pressume these are similar to the ones used on the door glass (picture attached), only shorter.
Looks like the thread should be 1/4-20, and the shoulder diameter should be 3/8".
I need to know what the shoulder length should be and the thread length. I'm assuming about 1/2" on each.
If anyone has one of these around, please measure it for me so I can clone it.
Thanks!
-Jim
"Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. "
Offline R/T hedkace
Re: Quarter window shoulder bolts
« Reply #1 on: February 11, 2009 - 08:11:20 PM »
Hope this helps.
Let me know if you need any additional measurements  :cheers:
Jeff
    Defending the Earth from "uptight" mods!!   an endless crusade..........
1970 Dodge Challenger R/T 440 4speed Dana
1970 Dodge Super Bee
1969 Barracuda
 Massachusetts
Offline Jim
« Reply #2 on: February 11, 2009 - 08:26:43 PM »
That measures pretty much the same as the door glass bolts, but with a smaller hex head.
I might actually have a couple of those, I just figured they needed to be shorter.
[edit]That IS a front glass bolt. Already have a few of those.
« Last Edit: February 11, 2009 - 08:35:33 PM by 471_Magnum »
-Jim
Offline 4 speed fish
« Reply #3 on: February 11, 2009 - 09:01:33 PM »
Hi, I just bought all 4 of the quarter glass shoulder bolts.The 1 you are talking about is 1 inch long not counting the bolt head.The shoulder part is 5/8ths long.I spent a fortune for these things.Hope this helps.  Bob
Offline Jim
« Reply #4 on: February 11, 2009 - 09:10:37 PM »
That's pretty much what I guessed.
These should work:
http://www.fastenal.com/web/products/detail.ex?sku=26328
I'll have to drill and tap the hole on the glass bracket to 5/16"-18, and put a washer under the head.
I won't asked what you paid for those bolts, but I'm betting this will be much more economical.
-Jim
Offline R/T hedkace
« Reply #5 on: February 12, 2009 - 02:17:06 PM »
Your welcome, no problem at all  :eek4:
Jeff
1969 Barracuda
 Massachusetts
