Author Topic: Removing door sticker  (Read 2779 times)
Offline usraptr
« on: February 11, 2009 - 09:31:18 PM »
Two questions. First, does anybody known where the secret/hidden vin # is on a '70 'Cuda?  Secondly, I'm going to be taking my body in to be media blasted in a week or so.  What's the best way to remove the door sticker without damaging it?
(Edited 8-1-17)
Offline Grancoupe
Re: Removing door sticker
« Reply #1 on: February 11, 2009 - 09:51:26 PM »
only two i have ever heard of are he rad support and near the windshield
Offline 73Chally
« Reply #2 on: February 12, 2009 - 08:57:24 AM »
There is a 3rd that law enforement knows of, but I'm not sure where it is (I guess that's the point of it, though).  I believe this came up before.  As for the door sticker, your best bet would probably be to make sure it is covered up well with several layers of tape or plastic, rather than try to take it off.  It will not go back on the same way because of the adhesive.  Mine went through blasting covered up and came out just fine.
Offline FY1443433
  • 1971 Superbee, 1970 Challenger R/T
« Reply #3 on: February 12, 2009 - 11:34:59 AM »
I can't help you with the secret/hidden VIN # but I can help your door tag.  Take some good pictures of it and take it off.  You either have to protect it very well or take it.  Once you remove it will destroy itself .
Here's where you can get a new one and that's what the pictures are for.  You can send them to ECS and they will reproduce an exact copy.  Completely legal!
http://www.ecsautomotive.com/
FY1
Offline 360 'CUDA
« Reply #4 on: February 12, 2009 - 12:00:04 PM »
You guys crack me up  :smilielol:
Offline usraptr
« Reply #5 on: February 12, 2009 - 02:26:46 PM »
Thanks for the advice.  I'm not sure which of the two I'll try, but that gives me some options.
(Edited 8-1-17)
Offline CudaEd
« Reply #6 on: February 12, 2009 - 03:50:16 PM »
I believe there is a number stamped on the left side of the trunk lip.
Offline usraptr
« Reply #7 on: February 12, 2009 - 06:09:00 PM »
Thanks, I'll check that. BTW where is the vin number on the radiator cowling/support. I can't seem to locate mine.
(Edited 8-1-17)
Offline 73Chally
« Reply #8 on: February 12, 2009 - 06:10:13 PM »
It should be right across the top, but a lot of times it gets filled in with paint.  If you run your fingers a cross you should feel the numbers, hopefully.
Offline 360 'CUDA
« Reply #9 on: February 12, 2009 - 06:29:38 PM »
come on guys.
First off there is no number on the trunk lip so don't tear off the weather stripping trying to find it.
1 VIN on the dashpad
2 VIN on the dr door sticker
3 VIN on the fender tag
4 sequence number on top of the cowl in front of the driver
5 Sequence number on the radiator support in front of the driver. Either on top or just below where the top "wraps around"
6 Sequence number on the engine block
7 Sequence number on the transmission
Of course the VIN appears on build sheets too but none of my cars ever have them
« Last Edit: February 12, 2009 - 06:31:54 PM by 360cuda »
Offline 360 'CUDA
« Reply #10 on: February 12, 2009 - 06:36:43 PM »
Here are some examples off my white car
Offline 73Chally
« Reply #11 on: February 12, 2009 - 06:55:07 PM »
come on guys.
There is another body VIN that very few know about.  After this thread came up I asked my friend in Law Enforcement where it is, but he asked me not to pass it on.  It's in a place that should last as long as the car does, and will not rot away with rust, or be replaced with new sheet metal.  They're sneaky bastards.
Offline 360 'CUDA
« Reply #12 on: February 12, 2009 - 07:36:20 PM »
I know where that is on Camaros (for example) but I think manufactures didn't put that extra number on cars until 1980 or so.
Sorry to hijack
I use clear shelf contact paper to cover up the door sticker. I stick it on big and cut it out carefully with an exacto knife. Paint right over it and peel the paper off when I'm done
(as seen in the above pic) it turns out pretty nice
« Last Edit: February 12, 2009 - 07:38:52 PM by 360cuda »
Offline usraptr
« Reply #13 on: February 12, 2009 - 07:40:13 PM »
Okay, Thanks for the photos.  I just located the radiator support number and cowling number.  As you said it was just under the rolled top.   :thumbsup:  Everthing matches!!
(Edited 8-1-17)
