Author Topic: Space-saver spare tire  (Read 1238 times)
Offline 70 383 SE
« on: February 11, 2009 - 10:14:12 PM »
I have to get a spare tire for my `70 383 SE and I was thinking of the space-saver ,for obvious reasons, but would it be hard on the rear-end,it is a sure-grip 355 gears, if I had to use it :clueless:      KEN    northern :canada:
70 383 SE Chally,2010 Chevy Silerado LTZ 4x4 crew-cab ,wifes car 2010 Honda Accord coupe......need to save gas somewhere.....hehehe
Offline LAA66
Re: Space-saver spare tire
« Reply #1 on: February 11, 2009 - 11:08:17 PM »
 I would think only if you ran it hard for quite a while it could be a problem. The rear end is designed to rotate at different speeds in corners though.
 Anyone know how/when the clutches engage or the possibility of heat build up. :dunno:
Offline wiging19
« Reply #2 on: February 12, 2009 - 02:08:10 AM »
My car came with one but I only use it for shows.  Can you buy replacement rubber for the rim and use it?  I can't imagine using the original just because I'd expect it to blow out on me. :dunno:
« Reply #3 on: February 12, 2009 - 03:46:40 AM »
to my knowledge the space saver was designed to be the same height as the original , just narrower
Offline 70 383 SE
« Reply #4 on: February 13, 2009 - 04:16:17 PM »
Looking at the ones I have seen in some pics they seem alot smaller diameter than the stock tires :sadwavey:
Offline ksierens
    • 70 Challenger Resurrection
« Reply #5 on: February 13, 2009 - 04:59:40 PM »
After it is inflated?  Are you talking about the space savers used in newer cars or the one used origionally?
Kurt - SE Michigan
« Reply #6 on: February 13, 2009 - 06:43:43 PM »
I know they made 14" space-savers, I'm not sure about 15".   :clueless: In any event, I'm sure the pictures you have seen are of the wheel de-flated... Thus saving space in the trunk.
Offline 70 383 SE
« Reply #7 on: February 15, 2009 - 01:54:37 PM »
Ya my car has 15" tires on it, so I wonder if one is made? :clueless: I would like to go with original but if new is better and safer then I guess that would be best. Does anyone know? :1zhelp: :bigsmile:
Alaskan_TA
« Reply #8 on: February 15, 2009 - 02:16:05 PM »
The space savers are all 14".
I would not use one for a real spare, they are too expensive.
Offline wiging19
« Reply #9 on: February 16, 2009 - 11:57:31 PM »
I think this part is more expensive than a steering wheel that has a rim horn.
Offline 70 383 SE
« Reply #10 on: February 17, 2009 - 03:06:18 PM »
Thanks guy`s I guess that answers that. :ylsuper: :bigsmile:
