Author Topic: Best aircleaner on a 4bbl 383  (Read 1096 times)
Offline Born_Fast
  • RIGHT PEDAL :: LEFT LANE
« on: February 12, 2009 - 05:05:53 AM »
Hi guys,
i'm using these snowy days to upgrade a few things on my Chally, before taking her out on the streets again in spring. One of the things that bugged me since day one, is the super small aircleaner the preowner installed. I read in another thread that anything smaller than 14x3" affects power and mileage, so i definitely want to improve the air supply. Btw i've got functional scoops on my rallye-hood, sine the preowner also removed the covers underneath and now they are open.
Below you see pics of my current setup: 383 with Edelbrock performer RPM intake and AFB 750 4bbl carb. Or so i was told, as i personally can't tell the different carb/intake models apart from looks alone.
As far as i know, a K&N filter unit with open top (pic below) will provide the best air supply. Specifically i am looking at the KNN-66-3010 with 4.5" total height, or the KNN-66-3050 with 3.125" total height. Both are 14" diameter and should fit on my carb.
Now can anyone tell me if these will fit under my hood? (at least the smaller one)
Thanks for your feedback!
« Last Edit: February 12, 2009 - 07:51:11 AM by Dreamcruiser »
nivvy
Re: Best aircleaner on a 4bbl 383
« Reply #1 on: February 12, 2009 - 05:15:26 AM »
MEK has that one.. ask him.. he has a 6pak hood though.... im sure there is a k&n that will tough
Offline Born_Fast
« Reply #2 on: February 12, 2009 - 07:59:37 AM »
Just to make sure i'd like to check the hood clearance (from carb to hood-underside). Any ideas on an easy way to do this?  :clueless:
« Reply #3 on: February 12, 2009 - 08:03:34 AM »
big ball of playdough
« Reply #4 on: February 12, 2009 - 11:47:40 AM »
I had to buy the K&N filter with the drop-base to get it to fit.
« Reply #5 on: February 12, 2009 - 12:02:56 PM »
3.5-4" with a drop base should fit easily not sure on 4.5"
Offline cudabob496
« Reply #6 on: February 14, 2009 - 03:23:38 AM »
A K&N will get you 10 horsepower, but a ram air box will get you 30+ hp. You get about a 1.5% power increase for every 10 degrees you cool the air to the carb. So on a 500 horse engine, if you lower your intake temp by 50 degrees, you pick up almost 40 horsepower.  Probably one of the best bang for the buck mods you can do! I have a set up on my 496 Cuda, using a 4 inch tall K&N filter. Playdough is good for checking clearance. I had to mil about 3/8 inch off the top of my M1 intake to get the clearance I needed.
2011 Kawasaki Z1000
Offline Bluemonster71RT
« Reply #7 on: February 26, 2009 - 08:19:22 PM »
Since your hoods inserts are off then why not the factory dual snorkal air cleaner w/ k&n in it?
1971 Challenger RT 383 4spd
Offline femtnmax
« Reply #8 on: February 26, 2009 - 10:20:35 PM »
Cudabob - Can you post a photo of your air cleaner setup??
Phil
« Reply #9 on: February 27, 2009 - 03:04:06 AM »
Google eddy 1411 & you will know exactly which carb you have
