Making more progress, slow but steady. I've come to the conclusion that I have two many projects/hobbies. Consequently I can't devote the time to the 'Cuda that I'd like. Anyway, sanded, polished and installed the trim around the bottom of the vinyl top and finally finished the new headliner install. Test fit the visors, RV mirror, dome light, front and rear window trim/moldings and side moldings. They will all have to be removed and repainted with some SEM Landau black, but at least the headliner itself is done. For my first headliner it came pretty good if I do say so myself. Minimum wrinkles and I haven't hit it with any heat yet so it should tighten up nicely when I do. I did put a small kink in the bottom of the passenger side sail panel. I'm hoping the side trim will cover most of it if not all.
