Author Topic: Brad' second '70 Cuda and first (and last) restoration project  (Read 125084 times)
Offline usraptr
Re: Brad' second '70 Cuda and first (and last) restoration project
« Reply #255 on: June 19, 2016 - 01:26:16 PM »
After what seems like forever.  My son and I re-installed the dash in my 'Cuda yesterday and it looks great, even if I do say so myself.  Still have to button up some things and connect a few more wires, and figure out why the "heat," "def" lever won't slide past the "heat" position, (any suggestions are welcome) but it's in.  Can't believe what a difference it makes.  It's actually starting to look like a car again after all these years.  New Dash Pros dash pad, three new speakers from S&M Electro-Tech, Inc who also restored my original AM 8-track radio (including the 8-track) and installed a I-Pod port, new heater control panel from Tony's parts.  My son and I bench tested all the gauges and they worked fine and I sanded and polished the plastic gauge cover.  I stripped and repainted the dash frame with the correct black swede lacquer and repainted any plastic trim pieces.  After I finish the dash installation I'll re-install the restored steering column and the front seats and the interior will be done expect for the center console which will wait until the engine/trans is installed.
« Last Edit: June 19, 2016 - 01:28:08 PM by usraptr »
(Edited 8-1-17)
Offline loco340cuda
« Reply #256 on: June 19, 2016 - 07:34:13 PM »
Looks great!
1970 Cuda 340 4-speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Offline Challenger in NC
« Reply #257 on: June 19, 2016 - 08:02:44 PM »
Looks fantastic. What was your procedure for testing the gauges and did you perform the amp bypass procedure?
Offline cudamadd
    • cudamad157071@gmail.com
« Reply #258 on: June 20, 2016 - 06:07:44 AM »
Great  job .Very nice indeed  .   :2thumbs: :aussie:
Go 4 a spin Ya Why Not.
Offline usraptr
« Reply #259 on: June 20, 2016 - 10:04:37 AM »
My son's a mechanic and did it a year ago so I'm not sure.  I think he used an ohm meter but I'm not sure.  I'll ask him and get back to you.
(Edited 8-1-17)
Offline 4 speed fish
« Reply #260 on: June 20, 2016 - 04:38:36 PM »
Was your shaker cable Knob  mounted in that location from the factory?
Offline usraptr
« Reply #261 on: June 20, 2016 - 05:20:03 PM »
I'm 90% sure it was, but could be wrong.  I went off these picture when re-attaching mine.
(Edited 8-1-17)
Offline usraptr
« Reply #262 on: June 20, 2016 - 05:24:53 PM »
This is the response I got from my son; hope this helps.
"I don't think there is a technical name for what we did.  We put power and ground to the various circuits to see if they functioned.  I am fairly certain your book(s) stated it is a 6 volt system at the cluster.  I used my power-probe hooked to a 12v battery you had lying around.  Since we didn't have a 6v source I very lightly rocked the toggle on the power-probe.  This made the lights flicker on/off and gauges twitch/move.  We did this to each gauge and light with the wiring diagram showing us where the power and ground was for each circuit. "
(Edited 8-1-17)
« Reply #263 on: June 20, 2016 - 06:24:20 PM »
Thanks. I need to test my gauge cluster out to make sure everything functions as it should before I install it.
Offline usraptr
« Reply #264 on: June 20, 2016 - 07:42:54 PM »
Discovered why my heater/defrost cable wouldn't move past half way.  Previous owner apparently broke the cable and re-bent a new loop into the end.  It's only 35" instead of the original 37"s.  :22yikes: Ordered a new cable today.  Hopefully this will solve my problem.
(Edited 8-1-17)
Offline AU6pack
« Reply #265 on: June 21, 2016 - 03:07:53 AM »
Very nice project. Great work  :wow:
Craig
Melbourne, Australia
1970 Challenger 416 6 pak
Resto thread - http://www.cuda-challenger.com/cc/index.php?topic=114787.0
Offline usraptr
Q
« Reply #266 on: June 22, 2016 - 06:33:10 PM »
Look what finally arrived at my doorstep today!   :bananasmi  Three weeks after the rest of the order.  I feel like a kid who has been anxiously waiting for Christmas morning!  Personally, I think somebody screwed up the order on the heads, but oh well they're here and that's what counts. Now the build can begin, well after I paint the engine. Pro-Maxx (formerly Patriot) aluminum heads; Quickfuel 880 CFM carb, Edelbrock Performer aluminum manifold; McLeod Heavy Duty clutch, Summit Racing Electronic Distributor, coil and ignition box;  Carter hi-performance fuel pump; ARP Head and other bolts; and Quick Fuel carb line.   FYI, I will take the heads to my Machine Shop to have them checked over before installation.
« Last Edit: June 22, 2016 - 06:36:50 PM by usraptr »
(Edited 8-1-17)
« Reply #267 on: June 22, 2016 - 07:41:55 PM »
Very cool. Will the heads be modified for improved airflow or just inspected?
« Reply #268 on: June 22, 2016 - 09:46:50 PM »
Exciting times ! Gotta love new shiny parts!  :grinyes:
Offline usraptr
« Reply #269 on: June 22, 2016 - 09:50:22 PM »
Just inspected and the intake push rod hole drilled out to accept a larger diameter push rod.  It's just a street machine.  No need for porting.
(Edited 8-1-17)
