It was bought in the early 80's think 82 And the company was located in Florida.
When I first got it the front of the 2 scoops were flat! They were the right shape but at the ends where the are opening would be was flat! Did not go in at all was just falt at the end. When i called them they said paint the hood and then paint the flat part black! So it did not look right.
So I Cut the scoops out glassed on a lip and bolted factory scoops on.
It is a top side and a bottom side glassed together.No structure under it like factory hood {ie}the top and bottom are both the same Like 2 skins for the top kinda.
It is heavy and a bolt on hood.
The back where the vents should be was smooth, So now I am cutting a whole in it and glassed in factory cowl vents in from a watsed hood.
So far This is the only one I have seen. Anyone?
I posted here since it is kinda a Body question
