Author Topic: 19" vs 22" Radiator Fan Shrouds  (Read 2339 times)
Offline AMXguy
« on: February 13, 2009 - 10:13:25 AM »
I found a guy who has a shroud off a '70 Challenger small block for sale but we don't know if it's a 19" or a 22".  I don't have a 22" one to compare it to  and it's 200 miles away so I'm trying to determine if it's the 22" one I need. it measures right at 22"  I'm not sure that means anything, were 19" and 22" the same shroud even though the radiator core was smaller? or is there a way to determine what it is?
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Re: 19" vs 22" Radiator Fan Shrouds
« Reply #1 on: February 13, 2009 - 10:36:46 AM »
Challenger's only had 22" and 26" radiators. Mine's a 26", so I can't help you.   :sadwavey:
Offline AMXguy
« Reply #2 on: February 13, 2009 - 11:10:31 AM »
Are you sure? the moparts radiator chart shows non A/C  E bodies with 318 and 340 engines having 19"
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #3 on: February 13, 2009 - 02:05:17 PM »
I've never seen a 19" in an E-Body.
Offline pink panther
« Reply #4 on: February 13, 2009 - 04:09:04 PM »
I have a 73 chally 340 and I have a 22"
how big is your radiator core across?
Offline AMXguy
« Reply #5 on: February 13, 2009 - 05:22:33 PM »
Interesting, I measured a 19" and my 22" and both are 24 1/2" to where the shroud bolts on. so the width of the shroud is the same, question is would the fan hole be the same? I have both radiators but no shroud so I can't say.
 If no 19" radiators were used that sums it up, but the moparts radiator numbers thing says the 1970 6 cylinder E body used a 22"  and the 1970 non A/C 318 and 340 used a 19". this makes no sense so maybe that's a screw up.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #6 on: February 13, 2009 - 06:46:56 PM »
The so called books aren't always right. So that would explain this. I understand your frustration.   :grinyes:
« Reply #7 on: February 13, 2009 - 07:35:41 PM »
that is confusing, it is hard to imagine that a 6cyl would have a biggerfan / shroud than a v8.
if it is cheap enough I would buy it, you should be able to sell it rather easy if it is wrong
« Reply #8 on: February 13, 2009 - 07:37:31 PM »
what is the part number on your radiator? I can go check against mine and see if they are the same.
Offline AMXguy
« Reply #9 on: February 13, 2009 - 07:50:56 PM »
2998954, but I think there are about 100 different 22" radiator numbers.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
« Reply #10 on: February 13, 2009 - 08:02:05 PM »
I just checked mine and it is a different number, I bought a 22" shroud from mancinis last year. I measured my radiator and it is just shy of 22"" the shroud is actually larger as it connects to the rad suport.  If you are measuring your radiator at 24 1/2" it's gotta be a 26" radiator I would think.
Offline quapman
    • Auto-Grip on Facebook
« Reply #11 on: February 14, 2009 - 09:54:06 AM »
My bone stock, mostly unmolested 73 Challenger with a 318 and no A/C had the original 19" rad. in it when I got it. Shroud was not present and I have since replaced it with a 22" aftermarket rad.
All three shrouds are different. They will measure approx. the same width as the core itself. Ask the seller to measure his for you.
