Author Topic: Front and rear window removal?  (Read 882 times)
Offline boydsdodge
  • Top end's unlimited....Aaaauuuuugghhhhh!!!!!!!!!!!
    • Boydsdodge
« on: February 14, 2009 - 05:54:39 PM »
Any one have knowledge on removing front and rear window trim and glass?
I am about to takle the roof window rot and need to get my glass out to do so.
Or does anyone know a good glass guy in the Toronto area that can do old cars.
I keep finding guys that have only been doing late model cars and don't know how to get past the trim.
Thanks.
Jackson from Toronto.
Offline farmertan
Re: Front and rear window removal?
« Reply #1 on: February 14, 2009 - 06:14:34 PM »
heres what i picked up at the cheap tool store it worked good just get behind the clip with light pressure up on trim i think it was 5 bucks
73 340 4sp 2nd owner since 85    brett
« Reply #2 on: February 14, 2009 - 06:17:37 PM »
there is an L shaped cutting tool available from Pricess Auto & other places to cut the seal , cant recommend a glass installer though
Offline farmertan
« Reply #3 on: February 14, 2009 - 06:22:52 PM »
i have to get my glass out too and i heard or read about a hot wire that one guy inside one outside can easily pull around window seal to remove window it accually gets hot and glides right through the seal, anybody know where to get this?
Offline boydsdodge
    • Boydsdodge
« Reply #4 on: February 14, 2009 - 07:38:35 PM »
I have that tool that is shown, but I didn't know how to use it.
That pick was worth a thousand words, thanks.
Offline e-tek
  • My website: http://edanneberg.googlepages.com/home
    • E-Tek Resto's
« Reply #5 on: February 14, 2009 - 09:08:42 PM »
The hot wire doesn't work well on this type of glass channel - just becuase the clips get in the way - a hot (electric) knife tool is better for Challengers (imagine a hot knife through butter). The glass guys have both tools. I used a cold knife myself (now imagine a cold knife through cold hard butter...). Either way, make sure you have the sealer cut completely away - don't try to pry or push the glass out - it'll break on you!
Offline boydsdodge
    • Boydsdodge
« Reply #6 on: February 14, 2009 - 09:21:30 PM »
Can the hot knife be bought or is it something I should fab up myself?
Offline femtnmax
« Reply #7 on: February 14, 2009 - 09:52:44 PM »
Could you take a soldering iron and replace the solder tip with a blade??
I used a knife and screw drivers, slowly pushed thru the seal bit by bit.   Took awhile, but it did the job.
Phil
Offline moprr
« Reply #8 on: February 14, 2009 - 10:28:05 PM »
I just removed my windshield I used the tool shown for the trim,  then cut the seal with a thin blade from the inside and out.  Still can't get the rear trim off its tight.
