Author Topic: Cuda steering problem  (Read 585 times)
Offline Husker Cuda
« on: February 15, 2009 - 12:08:08 PM »
Hey guys,
I have a problem with my Cuda steering maybe you can help?  The power steering seems to pull the box to the right.  You can raise the front end off of the ground, start it up and as you add throttle it turns the wheels to the right without touching the steering wheel.  Any ideas?
thanks
1974 'Cuda 512 stroker 650HP Indy heads, Hemi 4 speed, pistol grip - restored to new.
1970 GTX 440/727 Y4 Gold w/ black interior
1969 Camaro SS 396 4-speed X22
1970 Chevelle SS 396 - 375HP M22 4 speed
Alaskan_TA
Re: Cuda steering problem
« Reply #1 on: February 15, 2009 - 12:27:33 PM »
You need to adjust it. The procedure for this is covered in the FSM if you have one?
« Reply #2 on: February 15, 2009 - 12:33:18 PM »
the valve on the top of the steering box where the return line attachs has 2 1/2" bolts holding it in place , losson the 2 bolts & tap the valve gentily  up or down on the box to center the valve to stop it pulling
Offline Husker Cuda
« Reply #3 on: February 15, 2009 - 01:39:55 PM »
 :cheers: Thanks guys, I will see if I can get it adjusted.
