Author Topic: 1973 Fuse Panel..??  (Read 11027 times)
Offline 666 the legend
1973 Fuse Panel..??
« on: February 15, 2009 - 12:38:54 PM »
...Im lookin on the fuse panel under the dash and I didnt SEE what there FUNCTIONS were..?? unless Im just that BLIND..?? meaning...what fuse is for heater,lights etc etc etc...cause Im trying to FIX my DASH LIGHTS .and I dont have any POWER goin to the BULBS...and every FUSE checked out except for the..[ TOP RIGHT }...I got nothin..
« Last Edit: February 15, 2009 - 12:42:46 PM by 666 the legend »
67 Camaro SS/RS 4 speed[ royal plum]
68 Chevy II [Nova YENKO Clone]
68 Impala Custom
69 HURST/OLDS # 57
72 Trans Am 4 speed
73 Barracuda 340
Re: 1973 Fuse Panel..??
« Reply #1 on: February 15, 2009 - 01:11:34 PM »
around 72 they changed from listing the function to just using #s so you need the owners manual to reference which # does what
« Reply #2 on: February 15, 2009 - 01:33:54 PM »
From '73 manual
« Reply #3 on: February 15, 2009 - 06:07:40 PM »
...Thank you very much......And  I figured out that the..." DIMMER " was bad...Thats why the dash lights had NO POWER...gettin a new one tomorrow..thanks for the INFO on the Fuse panel..
68 Impala Custom
69 HURST/OLDS # 57
72 Trans Am 4 speed
73 Barracuda 340
« Reply #4 on: February 15, 2009 - 06:39:22 PM »
A bad dimmer is a common problem.   :grinyes: Even with a working dimmer, the dashlights are often dim.
I replaced the dimmer with a toggle switch, so the dash lights get the full 12 Volts, instead of something less. People usually can't tell by looking in my car.
I got bright lights now!!    :jumping:
« Reply #5 on: February 15, 2009 - 09:11:24 PM »
...One of my electrical engineer buddys came over and SAID...I could just piggie back 2 wires on the back of the dimmer to make it work..But i wont have the DIMMER FEATURE..So..?? If yah still wanna use your original switch,you can do it that way..
68 Impala Custom
69 HURST/OLDS # 57
72 Trans Am 4 speed
73 Barracuda 340
« Reply #6 on: February 15, 2009 - 09:21:57 PM »
that is probably what I would do is just jump the dimmer switch
