Author Topic: ballancing 360 crate motor  (Read 1823 times)
Re: ballancing 360 crate motor
« Reply #15 on: February 17, 2009 - 12:54:13 AM »
Cool thanks guys, but is there a difference from 360 LA and Magnum on the weight needed to balance?
I am not sure on the Magnum engine but I believe it is also external balanced
« Reply #16 on: February 17, 2009 - 01:12:37 AM »
this is incredibly helpful , I have the Mopar Magnum engine book here & cannot find any reference for the balancing of the old & new 360
Offline 71chally416
    • The Streetwalker
« Reply #17 on: February 17, 2009 - 01:15:20 AM »
The key is the Dampner. If it says "For externally balanced 360 only" then you need the weighted convertor or special flexplate or flywheel. There is no scenerio where they would use that with a neutral balance behind the motor.
« Reply #18 on: February 17, 2009 - 01:16:46 AM »
but is the balance weight the same ?
Offline 71chally416
    • The Streetwalker
« Reply #19 on: February 17, 2009 - 01:25:06 AM »
I believe so, front and back, but don't quote me. My Chally had a 360 when I bought it and when I took the tranny out it had a SFI flexplate with weights welded on and it had no vibration problems. I just removed the weights when I put the stroker in (it was internally balanced) and no problems. I've never had any other externally balanced motors though, so my experience is limited to that. I've always had forged crank motors.
Offline 71chally416
    • The Streetwalker
« Reply #20 on: February 17, 2009 - 01:37:07 AM »
You can get about any flexplate you need here and it looks like the Magnum takes a different plate than the gen 1 360>
http://chucker54.stores.yahoo.net/bm1.html
Offline boydsdodge
  • Top end's unlimited....Aaaauuuuugghhhhh!!!!!!!!!!!
    • Boydsdodge
« Reply #21 on: February 17, 2009 - 09:41:54 AM »
I thought so.
If the P/O did not know this like most of us, I could see that he might have just put a first gen 360 flywheel in.
That would cause a problem, wouldn't it. I think it would.
Jackson from Toronto.
Offline tactransman
« Reply #22 on: February 17, 2009 - 11:28:51 AM »
Flywheel /Flex Plate/Converter Balance
Magnum 360 (5.9) = 91 Gram Weight
Pre Magnum 360 =  120 Gram Weight
Terry-tactransman
Union, Mo.
« Reply #23 on: February 17, 2009 - 12:17:22 PM »
That would do it
Offline 71chally416
    • The Streetwalker
« Reply #24 on: February 17, 2009 - 03:49:47 PM »
I'm guessing the piston weights are different. I've seen those rebuilt factory short block Magnum motors call for neutral balance and the Pre-magnum 360 short blocks call for extenal balancing, so it depends on which one you use. The 360/408 crate motors say to use this weighted flexplate - P4876706 that looks like this>
Offline tactransman
« Reply #25 on: February 17, 2009 - 04:13:12 PM »
Every 5.9 engine Magnum or Pre-Magnum has to be externally balanced from the factory. The 5.2 magnum does not.
Terry-tactransman
Union, Mo.
Offline moper
« Reply #26 on: February 17, 2009 - 06:48:39 PM »
I was going to say... Magnum crates have special flexplates and flywheels... If you can feel the vibration as you raise rpms without the car moving, it's the engine... If it's only while driving, it's driveline..
