Author Topic: 'cuda frame specs.  (Read 1276 times)
Offline IMNCARN82
  • LeDZeP
'cuda frame specs.
« on: February 16, 2009 - 11:23:59 AM »
So,I'm about ready to start welding. There are some small differences at the back of the new frame rail. I'm looking for measurements at the rear,right under the shackle point(center to center) and at the frame where it turns flat at the bottom.Right at the start of the curved section of frame. (center to center)  Just double checking/comparing.  Thanks,Robert
« Last Edit: February 16, 2009 - 11:26:39 AM by IMNCARN82 »
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline Mt.St.BigBlock
Re: 'cuda frame specs.
« Reply #1 on: February 17, 2009 - 03:30:38 PM »
Hi Robert,
 Is the second measurement point you want right under that e-brake bracket
welded to the frame rail? I can get those for you this evening. Jeff
71 cuda 383 3spd manual gy9
« Reply #2 on: February 18, 2009 - 09:14:16 AM »
Hi,
  I didn't expect such "even" numbers but I got 48 inches exactly between the two
rear most threadserts behind the rear spring shackle CL to CL. The forward measurement
I got 36 inches exactly one inch back(rearward) from the rearmost 15/16ths holes near
that e-brake cable bracket. CL to CL.  Goodluck, looks like you into it deep there!  Jeff
