Author Topic: Stroker question  (Read 1764 times)
sleepychallenger
Stroker question
« on: February 17, 2009 - 04:27:52 PM »
If you can put a 440 crank in a 400 and make a 451, can you put a 440 crank in a 383 and make something?
Offline NoMope Greg
Re: Stroker question
« Reply #1 on: February 17, 2009 - 04:38:55 PM »
Yes - you get a 432.  Mopar Muscle did an article about a 432 stroker build a few years back.  Here's part 1:
http://www.moparmusclemagazine.com/techarticles/mopp_0605_mopar_performance_383_stroker_engine/index.html
You'll note that they got the crank from a 413, but the crank is interchangeable for all RB engines, so a 440 crank will be the same and require the same modifications.
Here's part 2, if you're interested.
http://www.moparmusclemagazine.com/techarticles/mopp_0608_mopar_performance_383_stroker_engine/index.html
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
sleepychallenger
« Reply #2 on: February 18, 2009 - 07:06:08 AM »
right on. maybe i will make this my next engine build project
Offline 71chally416
    • The Streetwalker
« Reply #3 on: February 18, 2009 - 11:58:58 AM »
Seems like a bunch of work to end up with a smaller motor than a 446. :clueless:
Offline moper
« Reply #4 on: February 18, 2009 - 12:06:11 PM »
It does work. Gets you stroke and not much else. The bores are small and have shrouding issues, but they work. I'd still run the 440Source B wedge 3.75 crank first. Much less work involved.
Offline 71chally416
    • The Streetwalker
« Reply #5 on: February 18, 2009 - 12:55:53 PM »
I guess the premise of the article is 440's are somehow scarce which isn't the case. That level of HP out of a 440 with reconditioned stock parts except for the pistons, big valves and some porting on iron heads along with a good cam and Intake is easy so I don't see the point.
« Reply #6 on: February 18, 2009 - 05:50:27 PM »
Drew, pm me if you want / need a new forged 440source 4.15 stroker crank for your engine
sleepychallenger
« Reply #7 on: February 19, 2009 - 07:21:28 AM »
i just want something different than what the majority of the croud is doing. i love my 383 and would like to run with that.
« Reply #8 on: February 19, 2009 - 06:53:31 PM »
I could go pick up a 64 413 block I had stashed :stirpot:
sleepychallenger
« Reply #9 on: February 19, 2009 - 10:28:47 PM »
would love to have that, but i dont think it will bolt up.  :roflsmiley:
Offline 71chally416
    • The Streetwalker
« Reply #10 on: February 19, 2009 - 10:32:35 PM »
Why not?  :clueless:
sleepychallenger
« Reply #11 on: February 19, 2009 - 10:34:25 PM »
is it the same bell bolt pattern? i thought they were different
« Reply #12 on: February 19, 2009 - 10:43:20 PM »
Bolts up and can be bored to a 426
Offline go-fish
« Reply #13 on: February 20, 2009 - 05:35:27 PM »
Jump on it Drew! H-E-M-I !!!
sleepychallenger
« Reply #14 on: February 20, 2009 - 05:51:37 PM »
ohhh  the fun we could have  :droolingbounce:
