Author Topic: Green Bearings  (Read 3128 times)
Offline 73EStroker
Green Bearings
« on: February 17, 2009 - 11:35:50 PM »
So everyone will know after I ask the question.
Do green bearing conversions still require the factory inner axle seals?? Or can oil sit against the inner seal part of the bearing?
Barry (Salmon Arm)
Offline 71chally416
    • The Streetwalker
Re: Green Bearings
« Reply #1 on: February 17, 2009 - 11:49:48 PM »
I'd never use those junk bearings so I don't know. Why not do the whole conversion and put in a 10 bolt rear?  :smilielol:
Re: Green Bearings
« Reply #2 on: February 18, 2009 - 04:57:35 AM »
a dana 60 is a 10 bolt :2thumbs:
bbscamp
Re: Green Bearings
« Reply #3 on: February 18, 2009 - 04:09:04 PM »
You can leave the lipped seals out, the O-ring on the bearing seals against the inside of the flange.  clean the flange good, scotch-brite it to smooth it too.  then put a film of grease on the O-ring and flange before slipping them in.  That being said, the inner lipped seals can stay if you don't want to remove them.  they won't hurt a thing.
Junk?  useable?  lots of opinions on that one
Offline 71chally416
    • The Streetwalker
Re: Green Bearings
« Reply #4 on: February 18, 2009 - 04:35:03 PM »
My friend did that conversion on his '68 RR race car. One of the axels pulled out the side of the car going down the track and wiped out a quarter panel. Quite a price to pay to not have to spend 5 minutes adjusting the bearing. I've never seen a stock Mopar tapered roller axel bearing go bad except for one on a Dart that had the small rear with a cover (7 1/4?) and it was a roller bearing.  :dunno:
Offline bp27
Re: Green Bearings
« Reply #5 on: February 18, 2009 - 04:40:16 PM »
Dana 60 is a 10 bolt? :screwy: Dana 60's have 12 ring gear bolts
Offline 71chally416
    • The Streetwalker
Re: Green Bearings
« Reply #6 on: February 18, 2009 - 04:55:45 PM »
I think he's refering to how many bolts hold the rear cover on.  :grinyes:
Re: Green Bearings
« Reply #7 on: February 18, 2009 - 05:30:40 PM »
 :screwy:   Back at you :poopoke:   The rear cover  (dana rear) is a 10 bolt. :bananasmi
Offline 73EStroker
Re: Green Bearings
« Reply #8 on: February 24, 2009 - 11:33:54 PM »
It is a Dana 60 out of a 73 6banger 3/4ton ford truck SG 3.73 tracLoc. I have the Dodge ends on the housing and it is the same dimensions as the stock rear end. I run the green bearings out of necessity not choice as the TracLoc has no center pin and buttons to spread the load across the two axles per the stock setup. This is waht I would like to do so does anyone know how to achieve this? CP is using the same diff with the sealed double thrust taper roller bearings from a 1/2 ton Ford. DTS supplied the special housing ends. there is an article on this in the Aug 2006 Mopar Action.
Stroker - what did you use on your Dana or was it a stock E body Dana which solves the problem?
Barry (Salmon Arm)
Re: Green Bearings
« Reply #9 on: February 25, 2009 - 02:15:08 AM »
BTW the green brgs do not use the inner seal to retain oil
Offline Bluemonster71RT
Re: Green Bearings
« Reply #10 on: February 28, 2009 - 09:58:00 AM »
Does that mean that you don't use them or they don't retain oil? Because MRE sent inner oil seals with my axles with green bearings.
1971 Challenger RT 383 4spd
Re: Green Bearings
« Reply #11 on: February 28, 2009 - 11:04:17 AM »
if you have them install them , having oil up against the green brg will not help as it is sealed , it is just that the green brg will seal in the oil without the inner seal as well
Re: Green Bearings
« Reply #12 on: February 28, 2009 - 11:45:01 AM »
Yeah I'll put them in since I had such a fun time pulling the original ones out :swear: I would feel incompleete if I didn't after that ordeal.
Re: Green Bearings
« Reply #13 on: February 28, 2009 - 11:54:13 AM »
just use a seal driver & tap them into place no prob unless you dont have a seal driver that size
