Author Topic: 440 with Dual Quads...Vacuum Advance ?  (Read 747 times)
Offline 7Dcuda
« on: February 18, 2009 - 01:51:31 PM »
For those of you with 440's and a Dual Quad Carb setup....do you utilize the vacuum advance?  I recently bought a 70 Cuda which the previous owner did not have the vacuum advance hooked up and said that with the 440 Dual Quad setup you shouldnt use the vacuum advance.
Re: 440 with Dual Quads...Vacuum Advance ?
« Reply #1 on: February 18, 2009 - 06:51:07 PM »
If the initial timing is bumped up a bit, you don't need to have the vacuum advance. I wouldn't worry about it.   :2cents:
Welcome aboard here, by the way.   :wave:
« Reply #2 on: February 18, 2009 - 08:01:05 PM »
it really has nothing to do with dual carbs ,with better cams you need more initial advance so generally I leave the vacuum disconnected
Offline moper
« Reply #3 on: March 01, 2009 - 09:57:34 PM »
Vacuum advance helps on every application except a drag racing car. Otherwise, unless there ius a reason you cannot wet it, it will not hurt anything, and will give you more power at part throttle and cruise and much bettter milage.
Offline 71chally416
    • The Streetwalker
« Reply #4 on: March 01, 2009 - 10:04:27 PM »
