Author Topic: Body bumper kit and weatherstrip  (Read 1050 times)
Offline kmyles
« on: February 19, 2009 - 06:32:21 PM »
JUST GOT MORE NEW PARTS IN!!!
BODY BUMPER KIT- DOES ANYONE KNOW WHERE ALL OF THESE GO?? I KNOW WHERE A FEW GO BUT THIS IS CRAZY!
WEATERSTRIP - ANY TIPS?? AND DOES ANYONE HAVE A CUTAWAY PIC OF THE TRUNK WEATER STRIP(WANT TO CONFIRM I GOT THE RIGHT ONE) AND TIPS ON INSTALLING THIS ONE WOULD BE GREAT.
THANKS
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Re: Body bumper kit and weatherstrip
« Reply #1 on: February 19, 2009 - 06:59:04 PM »
THANKS
That one is fairly simple. You have to glue it on around the trunk area. It should be longer than you need, so you will have a few inches to trim away. Of course the seem will be at the bottom someplace. The thickest part of the stripping is on the inside, if this makes any sense.
« Reply #2 on: February 19, 2009 - 08:01:01 PM »
to do the trunk weatherstrip I put masking tape all around the trunk opening first then I lay the weatherstrip into place & using 3M black glue I glue down a foot or so & hold it into place with the tape folding the tape up over the weatherstrip continue doing a foot at a time , then i CLOSE THE TRUNK & LET IT DRY removing the tape later once it is dried , I also use a small amount of glue to bond the ends of the weatherstrip together , the joint where you stop & start should be at the bottom center
« Reply #3 on: February 19, 2009 - 08:02:48 PM »
the body bumpers go everywhere , deck lid ,hood , doors , glove box door. ashtray door ,licence plate brackets  , you basically have to match what was removed
Offline kmyles
« Reply #4 on: February 19, 2009 - 11:04:25 PM »
I wish i had the option to match what was removed. The car is stripped and painted so I only know where a few go :pullinghair:
_________
Kevin
« Reply #5 on: February 20, 2009 - 03:31:41 AM »
I guess I need to drop by or take a lot of pix when I re-install mine
Offline kmyles
« Reply #6 on: February 20, 2009 - 11:10:15 AM »
Drop by...Hey I got an idea :thinkerg:, why don't you hop on the CC private jet an come on over!  :clapping::roflsmiley: :bigsmile:
 :cheers:
« Last Edit: February 20, 2009 - 11:13:11 AM by kmyles »
_________
Kevin
« Reply #7 on: February 20, 2009 - 04:54:37 PM »
Where are you
 your profile says alberta ?
Offline kmyles
« Reply #8 on: February 20, 2009 - 05:25:53 PM »
Grande Prairie. Where are you?
_________
Kevin
« Reply #9 on: February 20, 2009 - 05:40:51 PM »
Calgary
Offline kmyles
« Reply #10 on: February 21, 2009 - 03:21:36 PM »
So close but yet so far!!:( Next time I'm in Calgary I'll PM you and maybey we can get together for a coffee or a brew ;).
Kevin
_________
Kevin
« Reply #11 on: February 22, 2009 - 03:32:07 AM »
sounds like a plan  :2thumbs:
I am in Salmon Arm right now
