Author Topic: 833 fourth gear  (Read 1248 times)
Offline 340Challman
  • 70 Challenger B5 A66 4 spd
833 fourth gear
« on: February 19, 2009 - 09:28:07 PM »
Does anybody have a fine spline fourth gear they would like to sell? Mine has been injured by the PO who drove it without a pilot bushing. If I can get a good fourth gear I will swap it out, if not I will have it welded and re-turned. Anybody have one they don't need anymore? Thanks.
Kevin
Don't look back, I might be gaining on you.
        ___               ___
        _______________
(OO (____________R/T_) OO)
 \______________________/
      \______/    \______/
Re: 833 fourth gear
« Reply #1 on: February 19, 2009 - 09:51:03 PM »
Are they different to type and yr trans?
Offline 340Challman
Re: 833 fourth gear
« Reply #2 on: February 19, 2009 - 10:00:06 PM »
I don't believe so Al (as long as it is not the '75 and later OD). I thought the only difference was coarse or fine spline thru '74. Can anybody shed some light on this? :feedback:
Kevin
        ___               ___
        _______________
      \______/    \______/
Re: 833 fourth gear
« Reply #3 on: February 20, 2009 - 03:54:14 AM »
I believe there are 2-3 different ones , I know for sure there were at least 5 different gear ratios available
 Passon or Brewers would know for sure
Offline 340Challman
Re: 833 fourth gear
« Reply #4 on: February 20, 2009 - 08:53:11 AM »
CP I thought that was just for first thru third gears. Fourth gear should always be 1:1 shouldn't it? :dunno:  Unless like I said and it is from that OD trans. :dunno:
Passon, Brewers, You guys out there?
Are new gears available for the 833 like the Muncie?
« Last Edit: February 20, 2009 - 08:55:06 AM by 340Challman »
        ___               ___
        _______________
      \______/    \______/
Offline Changin Gears
Re: 833 fourth gear
« Reply #5 on: February 20, 2009 - 12:11:38 PM »
The '71 up 'close ratio' with the 2.44 1st gear had a differnet input shaft the earlier transmissions.  Thats how they changed ratios for the close ratio, with an input/cluster gear swap.  The actual 1st, 2nd and 3rd mainshaft gears were the same.
Re: 833 fourth gear
« Reply #6 on: February 20, 2009 - 05:36:53 PM »
the diameter of the gear chanes to mesh with the cluster gear
Offline 340Challman
Re: 833 fourth gear
« Reply #7 on: February 20, 2009 - 07:10:30 PM »
I have not been able to find any info indicating that there are different fourth gears other than the coarse or fine spline. Here is a site I found that sells parts and kits. :dunno:
http://www.tbtrans.com/a833_4_speed_transmission_pa.htm
Anyway, the trans is # matching to my '70 A66 Challenger so it should be fine spline unless someone changed it.
        ___               ___
        _______________
      \______/    \______/
Re: 833 fourth gear
« Reply #8 on: February 20, 2009 - 07:20:33 PM »
The '70 and earlier drive pinion has 24 teeth,  '71  and later has 25.
Offline 340Challman
Re: 833 fourth gear
« Reply #9 on: February 20, 2009 - 08:13:58 PM »
Thanks Gears.
So if anybody has a 24 tooth drive pinion laying around, I'd be interested in it. :bigsmile:
Kevin
        ___               ___
        _______________
      \______/    \______/
Offline LAA66
Re: 833 fourth gear
« Reply #10 on: February 20, 2009 - 11:18:57 PM »
 Mine matches also and it's a 23 spline. I just dealt with Brewers and they had a used 1-2 shift drum I needed. Maybe they have what you need also. :dunno:
Offline 340Challman
Re: 833 fourth gear
« Reply #11 on: February 21, 2009 - 03:13:10 PM »
Who is/are Brewers? How can I contact them? Thanks LA.
Kevin
        ___               ___
        _______________
      \______/    \______/
Offline LAA66
Re: 833 fourth gear
« Reply #12 on: February 21, 2009 - 09:48:00 PM »
 Here's the link. I give them a solid B+.
 http://www.brewersperformance.com/products.asp?id=115
Offline Rare_T_A
    • Freiss Family Mopar Site
Re: 833 fourth gear
« Reply #13 on: February 25, 2009 - 11:09:36 AM »
You may have already got one but this is the guy I got my 4 spd parts from for the RR.
http://auctionworks.com/StoreFrontProfiles/default.aspx?sfid=92390
He was real easy to deal with and very helpful on the phone also. One page 5 he has listed the gear your looking for.
« Last Edit: February 25, 2009 - 11:12:36 AM by Rare_T_A »
'09 Challenger R/T  5.7 HEMI Auto
'70Challenger T/A 340 727
Fargo, N. Dak.
My web Site:  http://freiss.co.nr
My Flikr Page: http://www.flickr.com/photos/102813164@N04/
I was born with nothing and I still have most of it left!
Offline 340Challman
Re: 833 fourth gear
« Reply #14 on: February 25, 2009 - 09:22:49 PM »
Very cool!
Thanks T_A
No I haven't bought anything yet. I like to sit and see what turns up a little before I jump. :bigsmile:
Kevin
        ___               ___
        _______________
      \______/    \______/
