Author Topic: '73 'Cuda numbers  (Read 1781 times)
Offline Purple73Cuda
'73 'Cuda numbers
« on: February 20, 2009 - 12:06:47 PM »
Hi Guys!
I am new to E bodies. I know where all the numbers are on the body of a B body. Where are the numbers stamped on an E body that should match the VIN tag? Do they stamp them on the radiator yoke and trunk rail like a B body?
Thanks!
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Offline fishn4cuda
  • Cuda Fan!
  • Ft. Jennings, OH
Re: '73 'Cuda numbers
« Reply #1 on: February 20, 2009 - 12:11:57 PM »
The vin is stamped on the core support (some on top, some on back), cowl top left side and thats about it on an E body
Cant kill the mean and ugly. Only the good die young...I plan to be here a while!!
« Reply #2 on: February 20, 2009 - 12:14:14 PM »
What would be stamped? Just the last 8 digits of the VIN?
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Offline 360 'CUDA
« Reply #3 on: February 20, 2009 - 12:32:11 PM »
like this
...The last couple of digits are smudged on the pic but you get the idea
« Reply #4 on: February 20, 2009 - 12:39:32 PM »
Thanks for the info. I want to check the 'Cuda when it gets a little warmer.
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
« Reply #5 on: February 20, 2009 - 05:10:05 PM »
I think I found some numbers stamped  on the radiator yoke. They are on the drivers side of the yoke on the top between two holes. I can't read them well because they are full of paint or aren't stamped very deep.
Since there are no numbers stamped in the rear of the car (like a B body), how could you ever tell if the car was wrecked and halved?
John
'73 Cuda 340
'70 RR 440+6
'66 Charger 383
Alaskan_TA
« Reply #6 on: February 20, 2009 - 05:41:25 PM »
Look for clues. Cars that are rear clipped are rarely the same color as the front half.
I know of '68 Barracuda that has blue floor pans in front with green floor pans in back. The welds were pretty obvious as non-factory as well.
Offline 360 'CUDA
« Reply #7 on: February 21, 2009 - 12:19:56 AM »
I have a '74 'CUDA like that.  It needs quarters and roof but I'm not sure it's worth rebuilding with it back halved like that.
