Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
Mini Starter Question (stock wiring / mini-shield?)
« previous
next »
Print
Pages: [
1
Author
Topic: Mini Starter Question (stock wiring / mini-shield?) (Read 1145 times)
Katfish
Resident
70 Challenger
on:
February 20, 2009 - 10:10:34 PM »
I'm looking at the 440source mini-starter for my 340.
Can I use the my stock molded positive battery connection without modifying?
They mention a mini-starter shield is needed or there will be a gap? True?
http://440source.com/starters.htm
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Mini Starter Question (stock wiring / mini-shield?)
Reply #1 on:
February 21, 2009 - 03:34:58 AM »
the factory end will work , it will sit twisted but can be bolted on without changing the factory end
the filler plate was used even with the factory starter to fill the gap between the starter & belhousing
Logged
quapman
Resident
Reply #2 on:
February 21, 2009 - 07:49:40 AM »
Depending on your application, you'll probably have to remove the terminal extension. The plastic cover snaps off, then the extension unbolts. I learned this one the hard way, trying to bolt one to a 440.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
February 22, 2009 - 06:32:59 PM »
it has to be removed on big blocks to clear ,it fits fine on small blocks
Logged
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Reply #4 on:
February 22, 2009 - 06:51:11 PM »
I had to remove the terminal extension for my 440, but I ask if you have headers or not? You might have to do some fishing to get the positive wires down in there if you do. It shouldn't be too bad though.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
Katfish
Resident
70 Challenger
Reply #5 on:
February 24, 2009 - 06:32:40 PM »
I have the factory exhaust, so it sounds like it will bolt up, but be twisted.
What about the shield, is that needed to cover a gap?
Thx
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #6 on:
February 25, 2009 - 02:03:14 AM »
it is not really needed but all the big blocks had them from the factory , I doubt you will be driving it in bad enough weather to really need it
Logged
Katfish
Resident
70 Challenger
Reply #7 on:
February 25, 2009 - 06:38:54 AM »
Thx for the info, I don't see any gaps with my stock unit.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Electrical
(Moderator:
Chryco Psycho
