Cheetah Forward Manual Valve Body
Author Topic: Cheetah Forward Manual Valve Body  (Read 5705 times)
nivvy
« on: June 03, 2004 - 07:36:04 PM »
Are the Forward valve bodies worth having??? I have a B&M shift kit waiting to be put in and would it be good to ad on the Cheetah valve body??? Does this affect the kickdown linkage either?
Offline 360 'CUDA
Re: Cheetah Forward Manual Valve Body
« Reply #1 on: June 03, 2004 - 10:54:20 PM »
put the shift down linkage in the attic and throw away the B & M suff
Turbo Action all the way 8)
nivvy
« Reply #2 on: June 10, 2004 - 01:35:12 PM »
Thats what I did...:0)
Offline 4Cruizn
  • HEMI FISH
« Reply #3 on: June 10, 2004 - 02:00:20 PM »
I could certainly use a kick down linkage for my convert if anyone has the parts.  Been looking for a while.  I understand there is a difference between the carter and the holley . . . like a half inch or so???  Any help is always appreciated!!
« Reply #4 on: June 11, 2004 - 02:40:06 AM »
nivvy
« Reply #5 on: June 14, 2004 - 02:39:07 PM »
It says on my box that it is absolutely not for street use....is that something they just put on the box?????
Cheetah forward manual valve body......part#17680
Offline TreeFrog
    • TreeFrog
« Reply #6 on: June 17, 2004 - 02:12:41 PM »
you got a slap stick you wanna get rid of?
the previous owner put one of those B&M gear selectors in the Challenger... I cant stand it!
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline GreenFish
« Reply #7 on: July 08, 2004 - 10:15:29 AM »
I have that valve body in my cuda, I drive it on the street alot ,have been for about 2 yrs now.  I kept my slap stick shifter, as I like the stock look,  it works great with it.  I drive it weekends when the weather is nice and race on occasion. Havent had any problems. I would highly recommend it.
Pigrider
« Reply #8 on: August 15, 2004 - 12:42:08 AM »
I have the Cheetah forward, in my rig.  Love the hell out of it.  Snapps the s--t outa my head.
Interesting.  I didn't know that this board had an auto censoring thing.  I guess you can't say s--t, on here.
« Last Edit: August 15, 2004 - 12:46:53 AM by Pigrider »
nivvy
« Reply #9 on: August 16, 2004 - 12:23:40 AM »
cool pigrider...i have the same dual 4 setup on my challenger......
Pigrider
« Reply #10 on: August 16, 2004 - 12:36:36 AM »
Ya have any pix of your set-up?  You have progresive linkage?  I have mine set really light, but can re-adjust so they both open, when needed.  Helps a little with gas usage.
Anyway, love to see some pix.
Offline DodgeFreak
  • Cars and trucks are my friends..
« Reply #11 on: August 16, 2004 - 07:09:18 PM »
i want to get a reverse manual valve body for my 904...where can i get one and how much...does cheetah make a reverse manual valve body for the 904 ??thanks.
74 Plymouth Duster- restoring
77 Dodge D150 shortbox- as long as i don't change my mind will be a step side dually diesel or a 383 powered truck
04 durango 4.7
Pigrider
Offline DodgeFreak
« Reply #13 on: August 16, 2004 - 10:42:19 PM »
Ok so whats the difference between part numb. TUR17680 and part numb.TUR17156?? thanks...also will this make the car shift hard?? like snap your neck hard?
« Last Edit: August 16, 2004 - 10:54:23 PM by DodgeFreak »
04 durango 4.7
Pigrider
« Reply #14 on: August 17, 2004 - 01:32:19 AM »
The 680 is a "forward" manual.  The other is a "reverse" manual.  The forward shift like a stock patern.  The reverse, 1st is where 3rd would be and 3rd is where 1st, would be.  Depends on the shifter you have, which one would be best for you.  The reverse is used to prevent you from  shifting into nuet. or reverse, by mistake, if you do not have a ratchet type shifter.  I have a forward, as my B&M shifter is a ratchet.  In other words, I can't shift into reverse without pulling up on the ratchet lever.
You would need a "shift kit" to make the tranny shift harder and faster.  The manual valve bodies make you shift manually,with more possitive shifts. You will have  no kick-down (passing gear)
