Author Topic: Heater cable attachment  (Read 1127 times)
Offline 340_6pak
« on: February 21, 2009 - 07:31:52 PM »
How does the heater temp cable attach to the hot water valve under the hood? The loop in the cable is a little small just to slip over the post, so I am wondering is there is a clip or something I am missing.
73 Challenger, 340.
Thanks;
73 Challenger
340 6pak
Re: Heater cable attachment
« Reply #1 on: February 22, 2009 - 06:54:12 PM »
Here's a pic on how it goes on. The clip that secures the heater cable to the heater top is a hard one to find.
There's 2 required. 1 for mounting the cable and the other to secure onto the lever.
« Last Edit: February 22, 2009 - 06:56:43 PM by Topcat »
Offline 70Plum
« Reply #2 on: August 15, 2013 - 11:19:13 PM »
Hi Topcat, can you post that pic again?  It is no longer available on the site but I have the same issue of trying to attach the loop to the valve post.  Thanks much!
« Reply #3 on: August 16, 2013 - 09:28:26 PM »
There's 2 types. One holds the cable secure and one for the wire part of the cable.
http://www.rtspecialties.net/proddetail.asp?prod=3431457
