The heads are off a 1970 U code 440. There are no numbers on the outside of the head that I can find. Under the valve covers there are two numbers "P 28439067-71" which is cast into the head and "11149" which actually looks like it's stamped onto a small metal strap that is then screwed into the head. Anyway, the engine was rebuilt in 1983 and has been sitting on an engine stand ever since. I'm going through it to inspect everything and just wanted to make sure it had the hardened valve seats before I put it back together. So far, everything looks good but I haven't taken the pan off yet to inspect the crank, rods and pistons.
