Author Topic: removing anti theft lug nuts with out the tool??  (Read 20776 times)
« on: February 22, 2009 - 01:32:27 PM »
Hi All!
Just got my "Baby" home ( 1970 Challenger ) was going to go over it when I looked at the lug nuts they require a special tool to get them off? I don't have that!
Any idea's??  They have slots milled parallel to the stud where a normal lug nut has the flats for the socket.   Pipe wrench?? They are starting to rust anyhow so they need to be replaced!
Offline 73Chally
Re: removing anti theft lug nuts with out the tool??
« Reply #1 on: February 22, 2009 - 01:39:10 PM »
Kind of sounds like the lug nuts I just bought from my local Discount Tire store.  The set I bought came with the special attachment.  If you can get a picture I can tell you if they are they same, and then tell you what brand they are so you can get the right tool.
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
« Reply #2 on: February 22, 2009 - 01:42:38 PM »
Weld nuts to the end of the locking lug nuts and remove them that way. There is also a tool that the tire shops use to break them off then they just replace the studs.
1996 Dodge Viper GTS Coupe
Offline 73Chally
« Reply #3 on: February 22, 2009 - 01:43:45 PM »
These are not the same ones I got, but very similar.
http://www.ezaccessory.com/Duplex_Spline_Drive_Tuner_Lug_Nuts_p/98-0420l.htm
Offline Marty73
  • '73 Challenger
« Reply #4 on: February 22, 2009 - 01:59:51 PM »
It's a pain in the neck - but get a heavy duty pipe cutter, then wrench to blade down until the lug nut splits. That's how i've seen it done
Comin' at ya like a herd of turtles
Offline 1black71rt
« Reply #5 on: February 22, 2009 - 02:08:14 PM »
A good tire shop has a tool you dive on to the lug nut. You just put a impact on it and spin them off.
Joe
1971 triple black challenger r/t
1971 charger se
1997 dodge ram SST
2010 challenger r/t
Offline JH27N0B
« Reply #6 on: February 22, 2009 - 03:55:05 PM »
I've heard of people using Vise Grips to get off locking lug nuts.
Another trick I've heard is to take a 12 point socket that is slightly too small, pound it on the locking lug nut with a hammer, and then unscrew it with an impact or breaker bar. After you get it off, put it in a vise and tap the socket off with a drift.
Use a Craftsman socket so that if you break it you can take it in and exchange it for a new one!
Offline 360 'CUDA
« Reply #7 on: February 22, 2009 - 04:30:14 PM »
I just did this last week to a Ramcharger that had locks on it.  I used a 1" China made impact socket (1/2" drive 6 point)  put an old breaker bar on it and hammered the end of the bar straight on the lugnut locks with a 3 pound hammer.
It didn't hurt anything and the lugnuts came right off.  A quick wack on the lugnut popped it off the socket with no problems
« Reply #8 on: February 22, 2009 - 06:41:47 PM »
Good idea's guys thanks!!
Offline gkring
« Reply #9 on: February 22, 2009 - 09:25:21 PM »
If all 20 are splined then it sounds like you have "tuner" style lugnuts. The most popular brand by far is Gorilla. You can go to a local Discount tire and get a wrench for them no problem. If you just have one on each wheel then you have splined locks and will have to use one of the other methods as they do require a special key. Pound on socket method seems to work the best and cause the least damage.
Greg
1970 Barracuda driver
Offline moprr
« Reply #10 on: February 22, 2009 - 09:29:31 PM »
I've done it with the 12 point socket like mentioned just hammer a smaller size on and it should work no problem.  A guy at a tire shop told me to do it that way.
Offline 71ChallengerSE
« Reply #11 on: February 22, 2009 - 09:47:39 PM »
My dad had this same problem with one of his vans, but he had the tool its just that the nut was stripped out. He welded a nut onto the end of the locking one and pulled it off with a regular socket. No hammering required
Offline quagmire
  • Traction Impaired......
« Reply #12 on: February 22, 2009 - 10:09:21 PM »
Those are just spline drive lug nuts, not antitheft.  The sockets used for those are all basically the same except for size.  You should be able to buy a set with the socket at any parts store.  One of my cars has those, and a regular 17mm six point fits them well enough to remove them if I lost the socket.  They arent like the keyed ones that use special sockets that are a PITA to find replacements for.
« Reply #13 on: February 23, 2009 - 08:20:19 PM »
Bought this tool at Sears today they come in a set. In the words of Tim Allen
" Damn right Sears! "
They worked great!! Justa few taps with a hammer, ratchet wrench and off they came!
Offline heminut
« Reply #14 on: February 24, 2009 - 10:58:44 AM »
I've got a set of those that my son bought me for Christmas a year ago. I've never had to use one, but it's good to know they work! :thumbsup:
1970 5.7 Hemi Cuda
