Author Topic: Fuel pump recomendations?  (Read 1169 times)
« on: February 22, 2009 - 07:56:22 PM »
I need a new pump for my 440. Which brands do you recommend? Any to stay away from? This is a street car.
Re: Fuel pump recomendations?
« Reply #1 on: February 22, 2009 - 08:40:20 PM »
Mallory if you want electric
Carter HV for mechanical
« Reply #2 on: February 23, 2009 - 04:51:15 AM »
« Reply #3 on: February 23, 2009 - 08:08:12 AM »
 :iagree: :iagree:
I have a stock carter 440-6 pump on mine and it does very good. Haven't had any problems
« Reply #4 on: February 23, 2009 - 09:04:43 AM »
No matter which way you go, I would recommend a fuel pressure regulator. My Carter HV is rated at 6 PSI, but was putting out close to 9 PSI.
« Reply #5 on: February 23, 2009 - 10:15:38 AM »
Thanks guy! Love this site!! The engine runs but it won't fill the fuel filter. It's one of those cheap see though filters. I have a mallory comp 140 new in a box but it's for my Buick with the noisy holley electric pump. It's way to noisy it's gotta go! I think I'll go for the Carter pump you all recomend! Thanks!
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #6 on: February 23, 2009 - 01:22:46 PM »
if the car runs drives fine you dont need a new pump.
Offline Aussie Challenger
« Reply #7 on: February 23, 2009 - 07:15:35 PM »
  If the filter is lying on its side or an angle it won't fill completely, pump may be OK..   :burnout:   :2thumbs:
« Reply #8 on: February 23, 2009 - 07:36:03 PM »
I got factory lines on my 440 and the filter is straight up and down.  It takes a special line at the pump with a curve and then the filter, then the line up to the carbs.
On a side note, that glass filter is not safe. The rubber o rings deteriate then start leaking gas.  I can find a spare line I might have if you are TRYING to go original. If not original, I'd like to keep it for any other member that may need it
« Reply #9 on: February 23, 2009 - 08:42:02 PM »
Thanks Moparal!! Your a great guy! You keep it though as I don't need a stock one. I know what you mean about those filters (glass) they are total junk! This one is a plastic see though type, not much better still a fire hazard in my opinion, I will be changing it for sure! I have just never seen one with just a dribble of fuel in it? They always are full? Yes it's on it's side. So I assume the pump is not up to snuff? It runs but I haven't got it on the road yet. Just tinkering for now! LOL i have lots to do before I look at changing the pump. This being a 6 cyl car now with a 440 I'm assuming I'll have to change the fuel pick up at the tank to a bigger one.
« Reply #10 on: February 25, 2009 - 02:17:33 AM »
the fuel filters often retain air in them , generally no issue
