Author Topic: battery cables 70 340  (Read 1278 times)
Offline KNOT0623
  • 1970 A66 Challenger
« on: February 22, 2009 - 09:08:19 PM »
Hi all
Does anyone know are the battery cables the same for a 340 T/A engine and a standard 340?
Thanks
Russ
« Last Edit: February 23, 2009 - 01:06:06 PM by KNOT0623 »
Get in, Sit Down, Shut up and HOLD ON!!!!
1970 A66 340 Challenger 4-speed
1970 T/A Challenger 4-speed
2006 Ram 2500 Diesel
2008 BMW M3 Vert
Re: batterey cables 70 340
« Reply #1 on: February 22, 2009 - 10:57:41 PM »
there is no reason for them to be different
Alaskan_TA
« Reply #2 on: February 22, 2009 - 11:52:55 PM »
Same part number for the 318 Challengers / Barracudas too.
Offline KNOT0623
« Reply #3 on: February 23, 2009 - 01:05:52 PM »
thanks...does anyone have the part numbers?
2008 BMW M3 Vert
Offline Aussie Challenger
Re: battery cables 70 340
« Reply #4 on: February 23, 2009 - 07:23:59 PM »
  Most factory cables were min. spec's. Unless you are building a show special upgrade to heavier cables and you will have less current loss in them when starting.   :cheers:
Offline LAA66
« Reply #5 on: February 23, 2009 - 10:42:14 PM »
 The ones MP sells for the small block fit right. Price isn't too bad either.
Offline JayBee
« Reply #6 on: February 24, 2009 - 07:59:31 PM »
This is from my 70/71 Parts Books
for Barracuda(B) and Challenger(J)
8-01-4  CABLE, Ground, Battery and Engine
             no4 gauge 23" long, except 426 engine     2983778
8-01-17 CABLE, Positve, Battery to Starter
             Motor to Starter Relay
              w/ 318 and 340 engine                         2983648
John
1970 Barracuda convertible
2014 Toyota Avalon
