Gauges..... Who needs them? (Burpin do)
Author Topic: Gauges..... Who needs them? (Burpin do)  (Read 1278 times)
Offline Burpin Chunks
  • http://mikescuda.net/cuda-challenger/burpin_chunks
« on: June 05, 2004 - 01:38:21 PM »
I am looking to replace my gauges in my non rally dash. Do they make analog or digital gauges that fit in the original spots in the dash. Maybe even in white face with a choice of color lites. Also my dash doesnt have a Tach and I was wondering if I can replace my speedo with a tach in its place.
Yall mopar masters please help.
lemonboy69
Re: Gauges..... Who needs them? (Burpin do)
« Reply #1 on: June 05, 2004 - 05:24:08 PM »
Voodoo gauges work real nice in there... so do a couple others but I just can't think of the names of them right now... ;)
LB
Offline Tim440RT
  • Get an R/T
« Reply #2 on: June 06, 2004 - 03:12:31 PM »
I think there was a discussion about it in the interior section once
1970 Challenger R/T 440
Offline BB73Challenger
« Reply #3 on: June 07, 2004 - 12:28:51 PM »
gauges on the cheap:
oil -
smoke billowing from under hood - high oil preasure
valves clacking - low oil preasure
temp -
radiator fluid droplets on windsheild - coolant hot
no coolant running from under car after freeway travel - good coolant temp
voltage -
car wont start after 20 minute drive - low voltage
car starts and you can listen to radio with the lights on - good voltage
tach -
rod through block - RPM's too high
car stalls ( manual trans. ) - RPM's too low
speedo -
cops with lights on - speed too fast
peolple pass you and shout obsenities - speed too low
 ;D ;D
Jeff from Cleveland, Ohio
Offline 72cuda
  • mmmmm, boiling gas
« Reply #4 on: June 07, 2004 - 12:38:53 PM »
Smoke from under dash: Ammeter on full discharge.
Don't ask how I know.
72 Cuda 383 4-spd
Drive it like you paid for it
Offline Don
  • All the Cats are Cruisin
« Reply #5 on: June 08, 2004 - 09:44:48 PM »
Go to cdignition.com then click on Dash Plates.................I thinking of doin this to my car!
« Last Edit: June 08, 2004 - 09:49:09 PM by Don »
Offline DodgeFreak
  • Cars and trucks are my friends..
« Reply #6 on: June 09, 2004 - 04:12:59 PM »
oil -
temp -
voltage -
tach -
speedo -
 ;D ;D
LOL thats a good one....
74 Plymouth Duster- restoring
77 Dodge D150 shortbox- as long as i don't change my mind will be a step side dually diesel or a 383 powered truck
04 durango 4.7
Offline Autophile
  • Kowalski... and the keys to a sawed-off weekend!
« Reply #7 on: June 11, 2004 - 04:12:24 PM »
The standard dash is a piece of cake to modify with aftermarket gauges. The holes are all standard sizes. Just unbolt your dash panel (the area where the gauges are, not the whole dash pad), separate the stock gauge cluster from the face plate, remove the stock gauge cluster from the car, mount new gauges in the face plate holes, wire it up, and remount the face plate to the dash. You will need to do some wiring work, but it's not too bad if you have any previous wiring experience.
The gauge holes fit 2 5/8" small gauges and one 5" large gauge. Autometer sells lots of gauges in these sizes. I am using (from left to right on the dash) Autometer tach, oil pressure, water temp, voltage, and gas level. I use to have a picture of it on this board, but it must have gotten deleted during the forum software change.
I did this mod about 14 years ago or so, I still love it, and I still get compliments for it.  ;D
1971 Cuda, black/black, 419 cu. in. 3G Hemi with twin turbos (build in progress), AlterKtion, Wilwood 12.19" disks, billet Rallye wheels
