Author Topic: Left hand Right hand thread, why?  (Read 1435 times)
Offline basement
« on: February 25, 2009 - 02:15:26 PM »
Why are some lug nuts CCW and others are CW?
Offline resq302
Re: Left hand Right hand thread, why?
« Reply #1 on: February 25, 2009 - 02:32:28 PM »
Think it had to do something with the rotation of the wheel and the possibility of the lug nut spinning loose if it was not torqued down properly.
Offline JH27N0B
« Reply #2 on: February 25, 2009 - 02:34:49 PM »
The ones on the drivers side are more prone to loosen while driving if they tighten clockwise. That is why Chrysler made them tighten CCW.
Too many problems with people breaking the studs turning them the wrong way when trying to remove, so Chrysler eventually joined the club in the early 70's and made them all the same.
Offline drewcrane
« Reply #3 on: February 25, 2009 - 02:44:52 PM »
 :popcorn:
Offline NoMope Greg
« Reply #4 on: February 25, 2009 - 02:59:11 PM »
That's exactly why they did it.  Most big trucks and buses are built the same way, due to the larger bolt circle.
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
« Reply #5 on: February 25, 2009 - 06:31:24 PM »
Thankfully they stopped this idea after 1970. You can convert over to all right turn bolts to save your sanity.
Offline Aussie Challenger
« Reply #6 on: February 26, 2009 - 03:03:35 AM »
  Modern wheels have a better taper on the lug nut and corresponding wheel surface. In the early days the surface area face was at a flatter angle and had less real force and the drivers side wheels would come loose. Also all wheels now centre on the axle protusion/hub leaving the nuts to only apply pressure to the back of the wheel against the axle flange.
« Reply #7 on: February 26, 2009 - 03:38:31 AM »
Freightliner & Western Star Trucks who are also owned by Chrysler also have left on the left side , it is to do with them being more prone to loosening on the left side with right hand threads as said above
Offline dodge freak 2
« Reply #8 on: March 27, 2009 - 11:33:46 PM »
People drove faster back in the 60's  :lol: Now a days its not needed  :roflsmiley:
Offline LAA66
« Reply #9 on: March 27, 2009 - 11:47:15 PM »
 Still got the original lefty driver sides. One of these days though..... :rofl:
Offline Changin Gears
« Reply #10 on: March 29, 2009 - 08:26:27 AM »
8 3/4" rear end ring gear bolts are left also, so they won't loosen.
