Author Topic: ??Bad relay??  (Read 2113 times)
Offline mike-philly
??Bad relay??
« on: February 25, 2009 - 11:29:43 PM »
I have a original 70 cuda,383 auto with air.Just got the car.While the car is running there is what I am guessing is a relay under the dash that keeps clicking on and off which is drawing a good amount of power(dims lights ,slows down turn signals).Any ideas on what it could be? I disconnected the power to the ac compressor and the draw still remains.   Thanks
1970 CUDA
2004 VIPER(MAMBA)
2007 ROAD KING
2008 PHANTOM CHOPPER
Offline GoodysGotaCuda
Re: ??Bad relay??
« Reply #1 on: February 25, 2009 - 11:58:15 PM »
Does it sound like a turn signal flasher? are the hazards on? turn signals? etc? There aren't really any factory relays besides the starter, and horn (off the top of my head)
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 4 speed fish
Re: ??Bad relay??
« Reply #2 on: February 26, 2009 - 12:52:10 AM »
The road lamps have a relay.
Offline Aussie Challenger
Re: ??Bad relay??
« Reply #3 on: February 26, 2009 - 02:25:02 AM »
  Check & see if the heater fan is staying on, or it could be drawing too much current. Something could also jamming the heater fan?   :2cents:
Offline 426HEMI
Re: ??Bad relay??
« Reply #4 on: February 26, 2009 - 02:56:28 AM »
The only other thing I can think of besides what every body said before now is that the Head lamp switch could be doing that also.  Check your harness going to your ignition also of overheating and shorts causing something to come on like that.  Just wanted to help if I could for you.   :2cents:
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Re: ??Bad relay??
« Reply #5 on: February 26, 2009 - 03:26:23 AM »
Probably a bad voltage regulator shutting the alternator off too long before sensing the need to charge again
Re: ??Bad relay??
« Reply #6 on: February 26, 2009 - 04:29:14 AM »
I think you will find your emergency flasher is on or wiring associated with it crossed.
Offline mike-philly
Re: ??Bad relay??
« Reply #7 on: February 26, 2009 - 05:09:47 PM »
Thanks for all your input. Whatever "it" is clicks on for about a minute then shuts off like a repetitive cycle.Everything is working ok, fan is off,signals all work,road lamps and head lite work as they should. The only thing I found was that the dash light dimmer switch has been bypassed.Im still clueless!
1970 CUDA
2004 VIPER(MAMBA)
2007 ROAD KING
Re: ??Bad relay??
« Reply #8 on: February 26, 2009 - 08:41:35 PM »
There is a time delay relay on some models that have given some members fits in the past...something relating to the heater motor if I recall correctly.
 Here is a schematic, you will see the time delay relay near the top a little left of center.
 I will search for the thread that dealt with this.
http://www.mymopar.com/downloads/1970/70BarracudaB.JPG
another schematic
Not the same symptom but on topic
http://www.cuda-challenger.com/cc/index.php?topic=46675.0
« Last Edit: February 26, 2009 - 08:55:26 PM by Bullitt- »
Re: ??Bad relay??
« Reply #9 on: February 26, 2009 - 08:52:50 PM »
The dimmer switch being by-passed isn't a surprise. They all seem to die eventually. Many of us have done the same, or in my case...replaced it with a toggle switch. My lights are much brighter now on my gauges.   :thumbsup:
Re: ??Bad relay??
« Reply #10 on: February 26, 2009 - 08:58:18 PM »
Mike why don't you just pony up & get one of Slotts nice restored switches? ....
    He could use the money  :poopoke:
Re: ??Bad relay??
« Reply #11 on: February 26, 2009 - 09:04:12 PM »
I need to see his feedback score.   :naughty:  I met the man...He is from my hometown. He did give me his address, so I guess I could always send a ticking box if I wasn't happy.   :misbehaving:
