Author Topic: Could this be why GM is in trouble?  (Read 2303 times)
Offline quagmire
  • Traction Impaired......
Re: Could this be why GM is in trouble?
« Reply #15 on: February 27, 2009 - 06:51:35 PM »
Yup, a lot of light duty rear ends nowadays use an induction hardened surface on the axle to serve as the inner race for what is usually a straight roller bearing.  When the bearing wears out it is usually only a matter of time before the axle gets chewed up too.  You may or may not be able to buy a axle bearing repair kit that basically moves the bearing, race, and seal onto a new area to save the axle.  You'll probably never have another problem with them after they are installed.
« Reply #16 on: February 27, 2009 - 09:14:49 PM »
I have a 2005 Suburban with 56,000 miles on it. The speedo quit and was not under warantee?? Tell me whya speedo should wear out???? Ever??? I have heard about the crapy rear ends on Gm too. If mine goes I'll build a 9" ford for it I'm not going to piss around with putting good money into a crappy rear end!
Offline lemming303
  • San Antonio, TX
« Reply #17 on: February 27, 2009 - 10:59:11 PM »
I love Ford trucks, the biggest reason is I abuse mine like crazy, always off-road with them, and I never have problems. The only major issue I had was a cracked head on my first truck, an 89 F150. The only reason it cracked is because I cut the lower radiator hose muddin and didn't know it. I drove it for two days without coolant in the Texas heat. On the second day I noticed it was bogging down and couldn't figure out why. I pulled over and found out it had no coolant. Other than that it was a great truck, over 200,000 miles on it. All of our trucks at work are Ford Super Duties and we abuse the hell out of them too, over 70,000 miles a year and lots of it off-road and pulling goosenecks. We haven't had any problems except with the new ones which I hate.
In GM's defense my Mom had a 97 Chevy 1500 that went 250,000+ with both doors banged up from wrecks but still running like a champ when we traded it in. It blew a head gasket once but that was around 225,000 miles and an easy fix. But I don't like the newer GM's at all, they drive and ride like crap, like the new Dodges. But Ford is way over priced, so you win some and lose some.
It sounds like your dealer is an ass. I would call the Chevy phone line like someone had suggested earlier.
Kevin
73 Challenger Rallye - first project
Offline MOPAR FANATIC
« Reply #18 on: March 04, 2009 - 01:48:15 PM »
Priderocks,i work for a gm dealer here in minnesota.if you want i can get the oem list price for you and what i could sell these parts to you for.i'm sure i could save you some dough.if you could get me the the last 8 digits of your vin i'll check it out for you. ment to post this last friday but just have'nt had time or did you get your truck taking care of already?
let me know if i can help you out with this.....
Dave.mopar fanatic...  :thumbsup:
« Last Edit: March 04, 2009 - 02:12:36 PM by MOPAR FANATIC »
71 Challenger 340 a/t
2013 Plum Crazy Hemi R/T 6SPD
« Reply #19 on: March 04, 2009 - 02:29:39 PM »
Heres what your looking at for prices...........
1st price is list,2nd is what i'll sell them to you for.
1-12471369 axel shaft 516.10  387.08
2-12471686 axel seal   13.23     9.26
2-12479031 axel brg     64.07   44.85
1-15286375 out pin brg  78.28   54.80
1-1234726 crush sleeve  6.00   4.50
1-15286376   out pin brg   24.78   17.36
1-26064028 pin seal   24.21    18.15
2-25824250 diff si brg   75.00   56.25
1-19179021 dif si gear & pin gear kit 380.32    285.24
1-15807693 cvr gskt 9.49   7.10
1-12479056 ring &pinion   854.03    640.52
these are o.e.m parts.
let me know if i can help you out further..
Dave...........
