Author Topic: Wiper Motor Issue  (Read 1609 times)
Offline 2cudas2go
Wiper Motor Issue
« on: March 01, 2009 - 09:14:11 PM »
Hi, I have a 71 cuda with the 3 speed wiper motor. All of a sudden the wipers no longer go all the back down to the base of the windshield. When I shut the wipers off they sit about a 1/3 of the way up. I have tried to bring it down manually but it feels like it comes to a solid stop. Any ideas as to what may have happened?
Thanks,
2cudas2go
« Last Edit: March 01, 2009 - 11:06:14 PM by 2cudas2go »
Re: Wiper Motor Issue
« Reply #1 on: March 01, 2009 - 11:32:14 PM »
the same problem all the wiper motors have , the reverse switch inside the motor has a problem & will not back the wipers down under the hood
Jules the Wiperman is rebuilding mine right now for the same problem , I tried to fix it first but got nowhere
Offline 2cudas2go
« Reply #2 on: March 02, 2009 - 10:55:46 PM »
Thanks Chryco,
 :2thumbs:
I guess I will be removing it and sending it away as well.
 :working:
2cudas2go
« Reply #3 on: March 02, 2009 - 10:59:16 PM »
there is no reason not to try to fix it , the test set up is the the FSM , but I got nowhere with mine
Offline 2cudas2go
« Reply #4 on: March 03, 2009 - 09:10:02 PM »
Thanks again Chryco
What do you mean by FSM
2cudas2go
« Reply #5 on: March 03, 2009 - 09:36:49 PM »
FSm =Factory service manual
Offline PlumCrazyRTSE
« Reply #6 on: March 03, 2009 - 09:38:44 PM »
Hey Chryco, any idea about how long it takes to get a motor rebuilt by Jules?
1970 Challenger R/T SE, 440 Six Pack, Super Track Pak, FC7 Plum Crazy Purple
1970 Challenger R/T SE, 440 Six Pack, Super Track Pak, FE5 Bright Red
« Reply #7 on: March 03, 2009 - 09:42:45 PM »
6-8 weeks
« Reply #8 on: March 03, 2009 - 09:46:52 PM »
Thanks, I've got one that could use a rebuild but I really don't want it off for that long.  I'll probably just wait until next winter.
Offline 2cudas2go
« Reply #9 on: March 03, 2009 - 11:22:15 PM »
I don't have a service manual but I will see what I can do once I remove it. I have a couple of buddies who know what they are doing when it comes to stuff like that and one of them may even have a manual.
I appreciate your help Chryco. :bigsmile:
2cudas2go
« Reply #10 on: March 04, 2009 - 12:36:45 AM »
there is a thread some where on the sote about this , , it is more complicated than you think , you need to cnnect combinations of 2 wires to positive & using different wires for ground , I would start by cleaning the reverse switch contacts under the cover , the cover is the round plate held on by 5 screw , 2 screws hold the wires in place , it that seems ok it has probably burned the reverse winding inside the motor from what i could figure out
