Author Topic: rear window cranks and door weather stripping  (Read 2706 times)
Offline kmyles
« on: March 01, 2009 - 09:34:13 PM »
OK so i'm just about convinced that i'm missing some hardware. got my door windows in so i decided to put in the rear quarter glass but I cannot find how the rear windows attach to the crank :banghead:. Also does anyone have any pictures of the rubber on the that goes on the door and around the bottom???? Have rubbers but I'm unsure how they fit. I will upload some pictures of my problem tomorrow.....
Thanks
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Alaskan_TA
Re: rear window cranks and door weather stripping
« Reply #1 on: March 01, 2009 - 10:04:59 PM »
Do you by chance have an A93 Coupe or the window assemblys from one?   :dunno:
Offline kmyles
« Reply #2 on: March 01, 2009 - 10:33:07 PM »
Have the window assembys but they were taken out previos to me getting the car. Now putting it back together I think that there are parts missing from the rear crank assembly.
« Last Edit: March 16, 2009 - 11:33:15 AM by kmyles »
_________
Kevin
Offline Travis72
« Reply #3 on: March 02, 2009 - 12:11:43 AM »
Here's some pics from my 72 Cuda.  Hopefully these help?   :dunno:
Travis
72 Cuda
Offline kmyles
« Reply #4 on: March 02, 2009 - 12:35:10 AM »
I knew it!! this is the bolt that I am missing. Is there something between the glass and the arm?? Does anyone have two of these they can spare??????
_________
Kevin
« Reply #5 on: March 02, 2009 - 02:17:54 AM »
there is a square slider & spring behind the arm on the regulator , the bolt goes through the round bushing you can see & through a square slider behind that & threads into the aluminum frame
R/T Specialties or Dean @ tilleman@platinum.ca are where I would try first
Offline kmyles
« Reply #6 on: March 02, 2009 - 11:56:00 AM »
I also ended up with these parts in the bunch. Any ideas where they go?? :dunno:
_________
Kevin
Offline sadil340
« Reply #7 on: March 02, 2009 - 02:10:21 PM »
The bracket is one of four that keep the front windows from rolling up too far. They're called "up-stops". They bolt with allen bolts to the inside of the door. Let me know if you need pics of where they go.
1970 Cuda 340 4-speed
3:55 SureGrip
Owned since 1974
Bought from original owner
Offline kmyles
« Reply #8 on: March 02, 2009 - 02:14:28 PM »
pics would be appreciated very much :ylsuper: :2thumbs:
_________
Kevin
Offline sadil340
« Reply #9 on: March 02, 2009 - 03:57:49 PM »
These were taken of the passenger door in a 70 Cuda. You can get new rubber tips from R/T Specialties.
3:55 SureGrip
Owned since 1974
Offline kmyles
« Reply #10 on: March 02, 2009 - 04:32:02 PM »
Thanks :2thumbs: I think I even see where the flat white plastic piece goes in pic #2
It's really appreciated :ylsuper: :cooldancing:
_________
Kevin
« Reply #11 on: March 02, 2009 - 09:44:25 PM »
the white plastc piece goes under the inner door handle
Offline kmyles
« Reply #12 on: March 02, 2009 - 10:36:26 PM »
What purpose does it serve :clueless: :dunno:
_________
Kevin
« Reply #13 on: March 02, 2009 - 11:00:36 PM »
Air leak & moisture seal
Offline kmyles
« Reply #14 on: March 02, 2009 - 11:02:00 PM »
Thanks!! :2thumbs: :2thumbs:
_________
Kevin
