Author Topic: Door Mirror Rivet Nuts and Rivet Tool  (Read 687 times)
Offline E-Body Products
  • E-Body Products
    • E-BODY PRODUCTS
« on: March 03, 2009 - 10:45:10 PM »
Does anyone have a door rivet tool?  I have a door that needs the riv-nuts.  R/T specialties has the rivets for $1.00 each, but I also need a tool.  I checked at Lowes for the tool and rivets, but I could not find them.  Does anyone know where you can shop for this?
Thanks,
Daniel
www.ebodyproducts.com
Offline FJ5_440
  • Wisconsin
Re: Door Mirror Rivet Nuts and Rivet Tool
« Reply #1 on: March 04, 2009 - 07:32:19 AM »
You can get it pretty cheap at Harbor Freight:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=1210
I have also sent mine to various members here.  They used it and then sent it back.
If you want to borrow it, just PM me your address and I will send it to you.
** Shane **
Offline cuda-cable
  • MOPAR or no car
« Reply #2 on: March 04, 2009 - 10:16:15 AM »
FYI ...you can install those using the appropriate threaded bolt, I use a cap screw, put a nut and washer on the bolt, thread it into the nut sert with the washer against the exposed face , insert in the panel, then tighten the nut similiar as to how you would a puller, the nut sert will collapse on the panel back and once tight you loosen the nut, remove the bolt. Do a trial part on a piece of sheet stock , you'll see how the nut collapses on the back.....dk
